Hi am very new to all of this, I have been considering the following speaker setup and would like to know if anyone has any suggestions for amps that can drive them for good two channel and surround :
Front: 703's
Center: HTM7
Rear: 705's
Sub: ASW 675
I have had a demo of the arcam AVR300 (I dont think it can handle the 703's), the Rotel RSP 1068 Processor with the RMB 1075 5 channel power amplifier, and a two channel Exposure 3010 Integrated amp. In my demo there was no sub, and the rears were not 705's, so I was basically just seeing how the amps could drive the 703's. I thought both did a better job of anything else I have heard (not that I have a lot to compare against - so any suggestions are welcome). I also used the two channel amp to watch a movie in stereo and thought that wasn't a bad option...
My issue is this, should I spend my cash on the rotel combination - and have an all in one (simple) solution, or should I go for the two channel Exposure 3010 (which is about 1/3 of the price), and add a surround processor/ additional amps at a later date. I am hesitant to go down this path as I do not know a lot about building surround systems from separates.
For now I am only after two channel, so I was leaning towards the Exposure 3010 integrated amp or some other amp that can drive the 703's well. Again any suggestions are welcome.
I would like to know if it will be difficult to incorporate a good two channel amp into a surround setup? And what is involved in the setup of such a system?
Also, since I am only after two channel for now I have been thinking of trying the RB1080, from a lot of the posts this amp seems like good value for money. As the RB1080 is a power amp do I need to purchase any other components for two channel and what will I need to purchase to incorporate this amp into a surround setup?
Sorry for the long post. I appreciate any advice.
Nath.
Front: 703's
Center: HTM7
Rear: 705's
Sub: ASW 675
Nath.
