Equalization for a subwoofer
  • Joe
    • Jan 2003
    Is equalization generally needed on a subwoofer? I have a DIY ported box with a BP1203 that sounds pretty good but I have never measured the FR. With a test CD and my ear, it goes to about 25 Hz.
    Anyone in Si valley, Palo Alto area, care to do a measurement for me and show me how it is done? I'll supply the drinks.
    thanks,
    joe
    The BP1203 will need something to drop the FR hump that's a function of the relatively high voice coil inductance.
    Here's a link that should be helpful
      Thomas, thanks for the link. I see he recommends several programs for room measurement:
      There are many good software programs for predicting/evaluating/measuring loudspeaker performance. CARA, ETF 5.0, and RPG Acoustics Room Optimizer look at loudspeaker placement and the interactions in with room.
      Has anyone actually used/compared these programs?
      I've just about decided to buy the Behringer mic and their DSP110 to power it, so I'll need a good program.
      He also put in a couple of compliments for TruRTA.
      • Pat
        • 1643
        Hank, the link was to a page on the "AudioWorx" site...Thomas and Jon's site.
        Pat's Page
        Pat's Page
          Pat, I don't understand your point. When I click on the link, here's what comes up ("audioworx" is in the URL):
          "Electronic room treatment and loudspeaker correction
          Passive room treatments work well, and are the preferred method of room correction. However, there are circumstances where passive treatment simply is ineffective or impractical. The solution is then to use active controls.
          The most effective form of active control is to utilize a parametric equalization. Parametric EQ is preferred over 1/3rd octave because of it's greater flexibility and control. Parametric equalizers range in price from $135-$5,000+ depending on their sophistication, accuracy, and sonic signature.
          In order to use active equalization it's mandatory to have a basis for adjusting the controls. This is usually created by measuring the frequency response of the room. Near-field (3" or less), 1 meter, or GP (ground plane), are measurement distances. The least expensive and most simple method of measuring loudspeaker performance in a room; is by using a device like the Radio Shack SPL meter, while sending sine waves through the loudspeakers. The resulting meter readings can be plotted in Excel, and the FR (frequency response) of the loudspeaker's performance in the room can be easily seen.
          If one has the ability to send a computer generated signal into their audio system, the NCH Tone Generator by Swift sound is a great freeware program. For those that can't use their computer to send the signals, many CDs are available with test tones burned on them.
          One of the better investments for those needing help to EQ lower frequencies, is the Behringer DSP1100P/1124P. Available for as little as $135, this device offers 12 bands of stereo parametric EQ. It is a very flexible and powerful tool. But the supplied instructions leave something to be desired. Also, it should be noted that the Behringer unit is fine for subwoofer frequencies. Since it digitizes the signal it's not recommended for use with full-range audio signals
          Here are links to 2 websites that describe in great detail how to use the RS meter and adjust the Behringer DSP1100P/1124P for optimal performance of subwoofers. The Brinkster Site uses the program ETF 5.0 and the RS SPL meter for making the measurements of the speakers performance. Sonnie Parker's BugSnap Website goes into great detail on the set up and use of the Behringer DSP1100P/1124P.
          For those using the Behringer DSP1100P/1124P, Anthony Gomez has created a need little program to program the equalizer. The program can be downloaded HERE
          TrueAudio's TrueRTA is an excellent program. The 1 octave freeware version will give the user a good idea of the program's abilities. The 1/24 octave version is an amazing tool when married to a proper microphone. The latest version has a .cal file for use with the Behringer ECM 8000 mic (see discussion below..."
          • Brandon B
            • Jun 2001
            • 2189
            I think his point was, you asked if anyone had used these. Since Thomas sent you a link to his own page, it's safe to say he has used the stuff.
            BB
            • Pat
              • 1643
              Brandon, you are correct.
              Hank, sorry if I was too vague :?
              I use a Behringer 1124 to eq my sub.
              Here are 2 of the links you mentioned but forgot to include. (I don't have Anthony Gomez' site in my bookmarks)
              Sin88 là sân chơi đặt cược trên mạng đáng tin cậy bậc nhất với phong phú loại hình như thể thao, sòng bài, quay hũ, săn cá. Đăng ký Sin88 nhận ưu đãi khủng từng ngày.
              Joe, I don't know if EQ is generally needed or not...I'd say it depends on how picky you are about flat response. I'd guess that most people don't even know why you would EQ a sub.
              If you do EQ for a flat response be prepared to be underwhelmed...especially if you are used to a peaky/boomy sub.
              Pat's Page
              Pat's Page
                • 16194
                I'll put in my 0.02 and say that our experience is that the best subjective (and measured) results have been achieved when we've first EQ'd the subwoofer for flat near field response through at least a half octave above the nominal crossover frequency just measuring the sub alone, without active crossover. Then, when the active crossover is added into the equation, the acoustic transfer function follows closely the electrical one in the crossover, and the matching between sub and mains is fairly optimized.
                If instead you choose to equalize at a listening position, you run the risk of things being fairly OK at that position, and not even close most other places- especially if the listening position you choses is subject to room peaks or worse, nulls. It's best to spend more time on optimum positioning of the sub and the listening positions to avoid eigenmodes. Use the search engine for more discussion on this topic. Acoustic solutions to acoustic problems.
                This EQ most often involves more work in the area above 75 Hz than you'd think- as well as some trimming of the response in the region below 40 Hz down to the system Fs.
                Note: NEVER use EQ to attempt to increase the output of a ported system below the port tuning! Most folks understand this, but in case you don't, below the port tuning, the woofer unloads, and the port output and woofer output are out of phase, resulting in weak output and low power handling. Generally it's a reasonable idea if possible to have a high pass (rumble) filter to cut out the infrasonic bass below the system tuning if your sub is ported.
                Sealed is a bit different; more LF output is possible, but it is still limited by the driver excursion and swept area. Hence, the desirability of systems like ThomasW's 12 Shiva's Dancing. No substitute for cubic inches! :B
                Best regards,
                • iron_monkey
                  how do people make a dipole subwoofer?
                  by iron_monkey
                  The thread about the new adjustable qts drivers made me interested whether its possible for me to make a dipole from them. It seems so simple at first, attach the drivers to a MDF board, and attach boards to the sides making it into a 'H' or a 'U'. Like this one ---> https://www.htguide.com/foru...
                  12 October 2004, 05:55 Tuesday
                  My BFD subwoofer EQ thread
                  Well, I'm FINALLY getting around to using my BFD to calibrate my two SVS PC-Ultra subwoofers. As expected, I'm running into a few hitches along the way as I'm learning and going through the process. Hopefully there are guys here that can help.
                  It took me a while, but I did go around and...
                  09 March 2006, 15:33 Thursday
                • oneoldude
                  Great Free Audio Measurement Software
                  by oneoldude
                  I was referred to this software yesterday. I have not yet fully tested the software but it looks really nice and the help files and manuals are really nice as well. :T
                  This is what it says about its self:
                  "The ARTA software consists of following programs:
                  06 February 2006, 11:26 Monday
                • Clive
                  Home Theater Glossary
                  by Clive
                  G'day Members. As part of our efforts to assist new and seasoned members I am starting this thread, to be used as a quick reference guide.
                  I am sure that there will be some missing from this original list so in that case I will ask that members can post the words and there meaning/explanations...
                  11 July 2005, 22:38 Monday
                • Blazin
                  Measurement Woes
                  by Blazin
                  Tweeter: DC28FS
                  Mid: RS150S x 2
                  Woofer: SD315-88
                  Finished a prototype.. I definitely have some leakage; however, this does not explain my measurement issues entirely (I think)
                  Subwoofer vented enclosure:
                  Impedance:
                  Impedance...
                  30 November 2007, 12:34 Friday
