VituixCAD v2
2.0.113.0 (2024-04-13)
Power dissipation- Added Ptot in watts i.e. total power dissipation to tooltip of driver, resistor, coil and capacitor traces. Calculated as power average within simulated frequency range of 5-40k; sum of power values divided by number of simulated frequency points. Power should be selected in View group to show Ptot.
- M-Noise peak response updated.
- M-Noise RMS response updated to produce crest factor and power dissipation more compatible with current Music-Noise.wav files.
- Added 'Generic -a12' to DSP list. Same as 'Generic', but biquad coefficients a1 and a2 are multiplied by -1.
- Added sample rates: 88200, 93750, 352800, 384000, 705600, 768000 Hz.
- Added sample rates: 93750, 352800, 384000, 705600, 768000 Hz.
- ETC smooth maximum increased from 8 to 32 samples.
- 'DSP system' combo box removed from Filter tab. Transfer functions are calculated using DSP settings in the main program.
- Added sample rates: 352800, 384000, 705600, 768000 Hz.
👍 2- Bottom
