SSP-800 CT/SSP-800 diagnostic or plan or all help
  • canAre
    • Nov 2018
    • 6
    Hello, I need help, contact, experience, Plan, Diagnostic Procedure ... Please, for an SSP-800 or CT-SSP-800.
    Mine, burned his fuse. After verification, the power supply was dead. I changed the power supply and the fuse but ... it does not boot anymore. It blinks and makes a continuous relay noise (black relay K201). I changed the relay, nothing changed.
    I check the voltage on different board, everything is beautiful except for the 5 volt. I have 4.85 volts instead. I have already heard that a modification for precisely this 5 volt (a bit too good or too low) existed?
    I also (even if it does not boot, it communicates with Downloader 1.2 on PC) re-made the firmware update 3.1.0 (I have the HDMI 1.4).
    There is a lot of small LED, there is probably a lot of clue ...
