hi pitched noise from CA-5300
  • jikdoc
    • Jan 2011
    • 8
    Hey there,
    I have a high-pitch noise coming from 1 output (rear Left) speaker. It's barely audible but always present and quite annoying. I've switched interconnects from my SSP800 and speaker wires, all the connections are solid and it's always coming from that output. Anyone have an idea of what could be causing it?
  • TomScrut
    • Nov 2013
    • 532
    Originally posted by jikdoc
    Hey there,
    Does it happen with no interconnects?
    Sent from my HTC One M9 using Tapatalk
    Music: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U
    • jikdoc
      • Jan 2011
      • 8
      hey, i just checked with no interconnects, no hum. i guess it's coming upstream from the amp. have to look at the interconnects, SSP800. it's with all my sources so i suppose it's at the SSP or interconnects. thanks
      • TomScrut
        • Nov 2013
        • 532
        Next thing then is SSP with nothing plugged in apart from mains an ICs to the amp
        • jikdoc
          • Jan 2011
          • 8
          I actually found that the noise occurred when the IC for that channel was plugged all the way in, if i slightly pulled it out, it goes away. Weird! any ideas?
          • TomScrut
            • Nov 2013
            • 532
            If they are balanced it's maybe that the shield or one of the connectors isn't contacting or something.
            • aarsoe
              • 795
              For future reference I would recommend everyone to get one of these or the many copies from other companies.
              Best way to check problems like this one - and thinking of how much we spend on gear in general then this should be a no-brainer..
