SSP 600 not responding to IR (from remote or via IR input)
  • sassicaia
    • Nov 2014
    • 4
    For some reason all of a sudden my SSP isnt responding to an IR commands. Normally I control it via the IR input on the back, but even the original remote isn't having any effect. I have been working on my system (adding, changing cables etc) the last couple of days, but cant figure what to do to fix it. Any suggestions, or is my first and only step likely to send it in?
  • madmac
    • Aug 2010
    • 3122
    My first suspicion would be the remote battery's !
    Dan Madden :T
    • sassicaia
      • Nov 2014
      • 4
      lol. Yup the batteries are good. Two different remotes dont work with it. Both the Harmony remote that sends the IR command via the IR input on the back, and the Classe remote sending it directly to the front. Batteries are charged.
      • mjb
        • 1483
        And you've rebooted the SP600 (this happened to me once)?
        Also, make sure you didn't plug a trigger cable into the IR socket, its the same connector.
        - Mike
        Main System:
        B&W 802D, HTM2D, SCMS
        • sassicaia
          • Nov 2014
          • 4
          Thanks for the suggestion. Yes I did. I was sure that would fix it to because it just doesn't seem right The IR sensor would "brake". By Reboot you mean turn the switch on the back on and off right? Is there a way to do a factory reset?
          • TomScrut
            • Nov 2013
            • 532
            My CP800 did this and a reboot cleared it
            Sent from my HTC One using Tapatalk
            Music: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U
