Which one is better ca-5100 or cav-180 I got 4 ohm speakers
Cav-180 or ca-5100 which one I need power to my lsi15
Last edited by deseroner; 12 May 2014, 02:59 Monday.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .Tags: None- Bottom
I sold my s700 amp and cav75 so I can get a multi amp instead.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Can't get 5200 at the momentMeridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Last edited by deseroner; 21 April 2014, 09:17 Monday.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
We'll in the end my heart said let's get the newer delta amps ca-5100 I got good deal on it . Anyone with feedback on how the ca5100 sounds . ThxMeridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
The CA-5100 is a great amp, and it won't have any trouble driving your 4 ohm speakers - it doesn't have the grunt of the 5200, but its a lot smaller/cheaper/lighter, and you may may not need that low end power anyway, especially not for all channels (e.g., in a small room, or with a sub-woofer). If/when you want something bigger, you can add a 2200/2300 for the front pair, and keep the 5100 for the surrounds (this is what I did). I'm sure you'll be happy with it.- Mike
Main System:
B&W 802D, HTM2D, SCMS
Classé SSP-800, CA-2200, CA-5100- Bottom
The CA-5100 is a great amp, and it won't have any trouble driving your 4 ohm speakers - it doesn't have the grunt of the 5200, but its a lot smaller/cheaper/lighter, and you may may not need that low end power anyway, especially not for all channels (e.g., in a small room, or with a sub-woofer). If/when you want something bigger, you can add a 2200/2300 for the front pair, and keep the 5100 for the surrounds (this is what I did). I'm sure you'll be happy with it.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Comes Thursday . Using meridian 568.2nm . Any opinions on a classe ssp300.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Will definitely report backMeridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
I thought the SSP300 was good for the 7.1 input but I didn't like the fact that there was no analogue pass through on the stereo inputs. So everything went through the SSPs ADC and DAC which kind of defeated the point in upgrading source components. The 7.1 input was the only one with the pass through. Apart from that I liked itMusic: Intel NUC -> Antelope Zodiac Platinum -> Classe CA-2300 -> B&W 802 Diamonds & 2x SVS SB13U- Bottom
Well I say it is very musical which I like so far . Going to try ssp300 , got me one to see if it sounds better than 568.2 . So far I am happy .Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
I use flac thru my bd player using analog outs . Meridian makes everything sound better. I have not even installed the last existing firmware that change all the dsp and sound. It is a hot amplifier I had to install a fan to exhaust the heat out.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
The amp looks great, congratulations, glad you like it. They like plenty of air around them though (the Meridian too) as you're finding. You might want to think about cutting some 2 inch holes in the cabinet base to let some air up through it. I not a fan fan (hate fan noise), and unless you have a good flow, you'll just be moving the warm air and dust around. I ended up sitting my amps on top (my cabinet isn't so high) so they could happilly convect. Interested to hear your comparison of the Meridian 568.2 and SSP-300.- Mike
Main System:
Quick iphone video http://youtu.be/iXJYvXEITr4Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
When you say that amp runs hot, any hotter than others you have owned? I think it operates in class A for a while - which makes sense with the heat.
Most importantly, how are you liking the CAV180 sound? How would you describe it?- Bottom
I have received it yet . I get it Friday.
I am trying to sell my 180 and get my hands on a delta got a great deal on a 5100. 180 sounds great but I still want a delta amp. I got a fan install helps keep the temps down
Sent from my iPhone using TapatalkMeridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Well they said it more detailed than cav-180 . I originally wanted it also .
Ok guys sold meridian today for 900 and ssp should be here any minute . Got 300 for 700 . Ok also bought me a ca5100 2100. plus it has trigger on ssp I need amp to trigger amp and subwoofer. Meridian made a little difficult to power on and off for WIFE. So you know I had to get it right. Will try out ssp with cav-180 still on sale 1400 . So will feedback soon.
Ok the classe ssp300 could not match my meridian 568.2 2.5 firmware at all musically , home theater I give a little edge ssp300. I also sold the 180 locally along with ssp300. It sounds good but I tell you the meridian is something else .so I will have feedback with ca5100 amplifier.Last edited by deseroner; 12 May 2014, 03:00 Monday.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Ok the classe ssp300 could not match my meridian 568.2 2.5 firmware at all musically , home theater I give a little edge ssp300. I also sold the 180 locally along with ssp300. It sounds good but I tell you the meridian is something else .so I will have feedback with ca5100 amplifier.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
Sent from my iPhone using TapatalkLast edited by deseroner; 05 June 2014, 23:50 Thursday.Meridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
No I took your advice and went for the 5200 for that extra kick .
I have a pf60 i also installed a mundorf silver/gold .47uf capacitor inside the amplifier outlet inside the pf60 , on the ca5100 sounded great very detailed. but why what problems did you encounterMeridian 861v4 rev one filter soon v8 firmware, classe ca-5100 , lsi15 modified capacitors ,snell xa1900 center,rs-7 klipsch surrounds. Bdt 220 bluray using as a flac player,oppo bdp80 for multi analogue 5.1 .- Bottom
