This subject gets no attention, here on the forum, not in the manual, so I thought it was not relevant.
I discussed this with technical dept of classe.
CP 800. Correct phasing cannot been seen, or know by us! (Bug). Hot pin should be up.
CA 2300. Can be seen via CAN bus. (Never used can bus, 12 v trigger was ok to me) Hot pin Should be left (fuse side).
It matters! Try yourself, if you have 800/2300
FYI
btw: i connected it perfectly statistically correct. 1 ok, 1 wrong.
FYI
