CP-800 questions
  • gimp
    • Sep 2011
    CP-800 questions
    I'm very interested in the CP-800 and have a few questions:
    1) Is it true that the USB input currently supports a maximum of 96/24? Are there any plans to upgrade USB to support 192/24? If so, when will it be available and will be upgrade be done through a firmware update or will the unit need to be shipped to Classe?
    2) When will the network connection be enabled? Will the upgrade be done through a firmware update or will the unit need to be shipped to Classe?
    3) Are sampling rate and bit-depth (e.g. 96/24) displayed when playing digital sources?
    4) Is there the capability to upsample?
    5) What is the current US MAP or MSRP?
  • Skyblue
    • Jun 2009
    • 504
    1) I dont know what resolution it can handle, however there is NO 192/24 material. Nothing. The only thing you can get is vinyl rips off the internet, and they often does not sound as good as the 16/44 cd version. Dont worry about it. At the time when such material appear at all, the usb interface will be long gone.
    • gerardhn
      • 352
      1) see above. All normal hi res availbale now ... it plays
      2) end of the year. It costs 500€ , so wil not only software i might guess.
      3)no, the software says it ..the cp says nothing
      4)no, i mean it does it automatically internally, it is not selectable.
      • busby
        • Jul 2011
        • 21
        1) Rear panel USB supports 32/44.1/48/88.2/96 kHz all at 24-bit. (The PC/Mac pads out 16-bit source material to 24 bits.) Front panel USB supports 32/44.1/48 kHz at 16-bit.
        3) The display shows the sampling rate in the centre-bottom part of the screen.
        4) Incoming sample rates of 44.1/88.2 kHz are up-sampled to 176.4 kHz; 32/48/96 kHz inputs are up-sampled to 192 kHz.
        • gimp
          • Sep 2011
          Thank you all for the responses. I actually own a number of purchased 192kHz/24-bit recordings. Some are ripped DVD-As and some are from HDTracks. For an example, please see:
          We invite you to join us in this evaluation of future consumer delivery formats. Download high resolution audio files from Norwegian 2L in stereo 96kHz, 192kHz, DXD, DSD and 5.1 surround. MQA and FLAC are lossless encodings derived directly from our original production masters. Enjoy the music!
          • style
            • 1562
            and a new phono card is the next upgrade:
            CP800 full preampli stereo in analog & digital !!
            (will be available around 04.2012 -> in Europa)
            style
            • Skyblue
              • Jun 2009
              • 504
              http://www.2l.no/hires/index.html
              Maybe I dont keep up, I dont know. I havent seen much, is all I am saying.
              • slauten
                • Aug 2011
                • 105
                Classe availability
                Has anyone taken delivery of an SSP-800 or CP-800 lately?
                I ordered mine a few months ago and it might be here by the end of Oct.
                I have talked to multiple Classe dealers all of them agree there are delays getting product. I have not found any dealer in North Texas with an CP-800 to review.
                I'm told the CP-800 just went into normal production, and anything out there were preproduction unit or demos.
                I would like to know what the heck is going on?
                See Ya,
                Steve
                  Does anyone know if an HDMI input is planned for the CP-800 in a future release?
                  I ask this question because it's not clear to me how 2-channel people like me will be able to take advantage of hi-res audio on Blu-ray music DVDs.
                  • mjb
                    • 1483
                    ummm, you must buy an SSP-800 for HDMI and multi-channel, to compliment your 2 channel CP-800.
                    - Mike
                    Main System:
                    B&W 802D, HTM2D, SCMS
                    • stuofsci02
                      • 1241
                      You can always get a BR player with built in HD codecs and analog outputs. Something like the Oppo BDP-83 / 83SE / 93 or 95.. I would go for 95 or 83SE for the better analog outputs.
                      Cheers...
                      Main System:
                      B&W 801D
                      Emotiva USP-1 Pre-Amp
                      Chord SPM-650 Stereo Amp
                      Oppo BDP-105
                      Squeezebox Touch
                      Second System:
                      B&W CM7
                      Emotiva UMC-1
                      Emotiva UPA-2
                      Oppo BDP-83SE
                      Grant Fidelity DAC-09
                        That would be a pity and complete overkill for me.
                        I have been given hope by reviews of the CP-800 such as this one http://audiophilereview.com/preamps/...o-pay-off.html which states "It also smartly takes 2.1 HDMI audio and video inputs from Blu-ray." I can't find anything on the Classé web site to support this, hence my question.
                          Cheers...
                          Yes, I agree that would be an option, but one of my motivations for considering a CP-800 is the high quality DAC inside it, particularly as this DAC is designed to convert hi-res audio streams delivered via USB.
                          • wildtangent
                            • 50
                            Well putting an HDMI video board and full DSP to decode the audio and give you a 2ch down-mix is kind of overkill as well. Some if not all of the few producers of BD-Audio discs, 2L for instance offer 2 channel Hi-Res FLAC files of their disc offerings. These files are a perfect match for the CP800.
                            Then again the SSP800 DACs are reputed by the same press as the best in class.
                            • audemars
                              • Oct 2011
                              Hello, fellow Texan!
                              I took delivery of my CP-800 ~2 months ago. Purchased new, factory-sealed from Shazad @ digitalear.com. Certainly owe a dedicated post with pics/review, but will say I'm VERY happy w/a 2011 Mac Mini (iTunes via BitPerfect app)-> Transparent USB -> CP-800 -> McIntosh MC452 -> ML Vantage.
                              My preamp-less foray began w/the PerfectWave DAC + Bridge. Incessant drop-outs (both network and eLyric iPad remote), firmware updates which drastically impacted SQ, collapsed soundstage, low volume resolution, etc. eventually forced a parting of ways. To my ears and others, CP-800 is in another league.
                              FYI, Robert Adam @ Classe claims the Ethernet update is slated for "sometime" in 2012.
                              See Ya,
                              Steve
                              • Aquarius
                                • 48
                                I plugged headphones in CP-800 but there is no automatic line selection so there's no sound.
                                Does anybody knows how to listen music on headphones using CP-800? :/
                                • wettou
                                  • 3389
                                  I was wondering if any of you have ever compared the following for better sound quality for HD music Files?
                                  OPTION 1: Oppo BDP-95 SPDIF to CP-800
                                  Using the DAC in the CP-800
                                  Wolfson WM8741 32-bit/192kHz chip
                                  or
                                  OPTION 2: Oppo BDP-95 XLR- XLR to CP-800
                                  Using the
                                  Sabre ES9018 DAC in the Oppo, BDP-95
                                  • Srrndhound
                                    • Sep 2008
                                    • 446
                                    Do the speakers mute when the headphones are plugged it? If so, then the unit is detecting properly.
                                    • wettou
                                      • 3389
                                      USB cable?
                                      Can you tell me what USB cable you use and does it make a difference?
                                      Any one tried Furutech GT2 cable
                                      Also I read that you need to stay under 3 m, why?
                                      • Aquarius
                                        • 48
                                        Well, that's the problem. Speakers DO NOT MUTE after plugging the headphones. :/
                                        • beden1
                                          • Oct 2006
                                          • 1676
                                          Seriously? What's the point of listening to your headphones when you are probably trying to keep it quite in the house at night, if you can't also mute the external speakers?
                                          Hopefully that is just a software glitch!
                                          • Aquarius
                                            • 48
                                            The fact is, ONLY right channel mutes. Definitely a hardware failure.
                                            But here's the tip... If you are using CAN-Bus between CP-800 and power amp, you can select power amp through the menu on CP-800 and select MUTE option on power amp. And there you go! Not bad for a 5000 € gear. Damn!
                                            • RebelMan
                                              • 3139
                                              Thre are no plans for an HDMI enabled CP-800. When I discussed this with Classe' two years ago they said HDMI would not be part of any running changes planned for the existing platform. Their decision was partly due to the added cost the CP-800 would incur plus getting hires content into the unit does not require an HDMI interface for 2CH audio.
                                              • Skyblue
                                                • Jun 2009
                                                • 504
                                                or
                                                Using the
                                                I have neither, but I know one who has Oppo 95 and SSP800 and he preferred the oppo dac to the ssp800.
                                                • wettou
                                                  • 3389
                                                  :B:rofl::lol: :W :demon:
                                                  • beden1
                                                    • Oct 2006
                                                    • 1676
                                                    I can't see how this is possible!
                                                    • RebelMan
                                                      • 3139
                                                      If your intentions are to keep the signal as faithful to the original as possible then there is no choice but OPTION 1. Less is more in this case.
                                                      • wettou
                                                        • 3389
                                                        Except that for SACD it won't work
                                                        See the new Mark Levinson with HDMi and DSD :T Only $100 more than the Classé
                                                        "Finally, the $6000 No560 Digital Audio Processor has two HDMI inputs, also with DSD-direct capability, two optical and two electrical S/PDIF inputs, an AES/EBU XLR input and three USB 2.0 inputs, plus RCA and XLR analogue outs.
                                                        It has 'isolated digital and analogue circuitry with independent power supplies, asynchronous clocking to ensure jitter-free performance from the dual 32-bit DACs, premium quality internal components throughout and many additional enhancements."
                                                        Founded in 1972, and now part of Harman Group, Mark Levinson is launching new preamp, integrated amp, SACD player and digital processor
                                                        • Srrndhound
                                                          • Sep 2008
                                                          • 446
                                                          But the 560 has no bass management or EQ. Apples to oranges.
                                                          • wettou
                                                            • 3389
                                                            !! OK that's interesting
                                                            • RebelMan
                                                              • 3139
                                                              Uhhh, you said.. "music files" No such thing on SACDs.
                                                              • alebonau
        • 992
        could just pick up the nad 51
        hell of a lot cheaper and hell of a lot more revolutionary. saw one at the recent melbourne hifi/av show. lovely well made piece that seems quite heavily featured including all manner of digital inputs including hdmi and a high resolution pre amp, and just about all manner of connectivity possible.
        • roubaixpro
        • Mar 2012
        • 4
        SSP-800 / CP-800 Combo Question
        I am planning to get an SSP-800 for home theater use but also want to listen to two channel audio using a computer audio setup. I was initially planning to just connect a music server using a separate USB to S/PDIF converter and DAC to the SSP-800.
        However, when I visited a Classe dealer, he recommended getting the SSP-800 for home theater use and the CP-800 stereo preamp processor for computer audio use. Regarding the CP-800, my understanding that this has both a stereo analog/digital preamp and an asynchronous USB DAC contained in one component. This means that I can plug an Aurender S10 music server into the CP-800 using a USB cable and output to the SSP-800. The CP-800 accepts PCM data streams up to 24bit/192kHz sampling frequency. The dealer said that the DAC in the CP-800 was far superior to the one used in the SSP-800.
        Does anyone have experience using the CP-800 for computer audio use and if so what is the sound quality like compared to a high quality CD player? Classe claims that when playing computer audio files, the CP-800 surpasses the sound quality of a good CD player.
        The dealer also said that Classe products are “price protected” and that he could not sell them below the list prices. Is it true that there is no room for negotiation on the list prices for new components? Can the dealer lower prices on only demo items?
        • Skyblue
        • Jun 2009
        • 504
        I have heard the price protected thing as well. However, while the dealer can't give you a discount on the classe, he can throw in a lot of other stuff for free...
        • Tweir
        • Oct 2006
        • 161
        That's a good way to stay in business!
        • beden1
        • Oct 2006
        • 1676
        Since when have Classe dealers stopped offering discounts?
        • audioaddict9
        • Apr 2012
        • 4
        CP 800 Digital Source Unit
        Hi all,
        Greetings from sunny South Africa
        I hope i"m posting in the correct forum here, but here goes!
        I recently purchased a CP 800 and i have read numerous opinions stating material sounds better through the USB inputs from a digital source than from a cd player.
        Now in the context of my system, my Electrocompaniet cd player sounds far better than with the same cd converted to Apple Lossless and played through my Ipad.
        Now perhaps i am doing something wrong. Maybe someone can offer some advice?
        My main reason for posting is this: what would be the optimal source unit for this preamp? Would you say a Mac (Macbook or Mini Mac perhaps?) or is there another option that would work better?
        Thanks in advance,
        AA
        • Skyblue
        • Jun 2009
        • 504
        Setting up a computer to play via usb is a science in itself.
        Your ipad is NOT a good audiophile source. Itunes for mac can be, but you'd need to set it up with amarra or some other plugin to make it sound good.
        For pc's also require some setup. Either use asio4all with foobar for instance, or try jplay (jplay.eu) or some of the other audiophile players and plugins that exist out there.
        Any barebone computer, be it mac or pc, can be improved tremendously when it comes to soundquality.
        • audioaddict9
        • Apr 2012
        • 4
        Thanks for the response Skyblue.
        In your opinion would a mac mini with amarra be a fair way to start?
        • rgbyhkr
        • 60
        Here's a great resource for creating and managing DIY computer based music servers:
        • audioaddict9
        • Apr 2012
        • 4
        Thanks rq, very informative site that..
        • Skyblue
        • Jun 2009
        • 504
        I myself prefer pc's, but macs are used by many. Incl. classe and ayre... Mac mini would be a good start. Also read Ayre's mac setup guide. I used their pc guide and it was very good.
        • audioaddict9
        • Apr 2012
        • 4
        I think i may head the mac mini route, now which model to buy! Thanks for the input (that ayre guide is the bomb)
