Ca 2200 with 802d
  • Cambs12
    • 191
    Ca 2200 with 802d
    ABout 2 months ago i bought one of the last pairs of B&W 802d,which i love.Will probably buy Classe CDp202 to partner this.I will change amps also(got MF Trivista at moment).Will a 2200 be powerful enough to drive the 802d to high levels,room size 22 feet long,width 13 feet.An ex-dem unit has come up,at a good price.Or should i wait for Ca400 monos?
  • mjb
    • 1483
    A ca-2100 will drive the 802D's very, very nicely, infact thats what I'm using and it sounds fantastic. Having said that, a ca-2200 is on my Christmas list, as I believe 3db extra dynamic range will make a positive difference. The ca-2200 is certainly a popular amp for 802d's. I personaly think a ca-400 would be overkill.
    - Mike
    Main System:
    B&W 802D, HTM2D, SCMS
    • gerardhn
      • 352
      I use this combo.
      Perfect combination.
      Cannot judge if mono's are overkill. I am sure you can find some experiences here or on B&W forum, using search function.
      • wettou
        • 3389
        I use the CA-5200 and they sound great. I always wanted more power, I wouldn't mind contemplating the CT-M600
        Just the price is hard to swallow even with discounts
        I am looking to try Emotiva XPA1
        • caberxx
          • Jan 2010
          • 23
          Any decent quality, decently powered amp will make these speakers sound great. However, they do love power - you just can't seem to feed them too much. I had two CA-M400 mono blocks and they worked very well. So, I added two more. Now I have two of these mono blocks for each channel. Not overkill at all. The speakers love the power. The 2200 would be a great choice. It also gives you the flexibility to add another 2200 later on and use one for each side.
          • style
            • 1562
            2x Cam400 for the L&R (400 for each chanel) or a CA2200 in biamp. :T
            2 x cam400 I think is a extra noth enough......
            in place of the new line Ctm600, I will be happy with 2 x ctm300 or a ct2300.
            in place of a emotiva I go with a Rotel D Ice ops:
            greetings style
            • mjb
              • 1483
              So for the OP, there you have it....
              You'll need several kilowatt amps bridged and will still have a craving for more power :roll:
              - Mike
              Main System:
              • style
                • 1562
                I agree 100%.
                Mike with a CA2200 your 802D will be sound very good.
                You will be happy :W
                greetings
                Style
                • mjb
                  • 1483
                  Style, its on my list.. hopefully for Christmas ;-)
                  Let me know when you next have one!
                  - Mike
                  Main System:
                  • style
                    • 1562
                    Mike read PM :W
                    • garak
                      • 310
                      I'm going to play devil's advocate. I've heard 802Ds driven by a pair of CAM-400. They sounded magnificent - the soundstage was expansive, and the imaging was so clear. My CDs sounded like SACDs.
                      I would say that if it's within your budget, go for the CAM-400s.
                      • style
                        • 1562
                        Hy man!!
                        I have to send my PM....
                        yesterday I have the fortune to have at my home a "guru" from Hifi cables:
                        I halve changed all the source & premapli sector cables, a coax. cable, a "power bar - well similar": my stage from the 1.5m. high is going to the 3D:
                        if you have a lot of CAM, or what do you will for ampli and the clabes are not at the level te sound still....
                        with a 6k.$$ cables I have listen my system like never and most important sound "open, sounstage without frontier" : a new preampli & a couple of Cam400 with the "old" cables dont give me the same sound.
                        welll, if your badget is a $. 100k. : go with the Cam and the new cables... :W
                        http://www.fabercables.com/uk/home.htm
                        Style
                        • style
                          • 1562
                          douple post
                          • gerardhn
                            • 352
                            Hi Cambs12,
                            Everybody makes you crazy.
                            2100 = fine, maybe what under the top
                            2200 = perfect!
                            2*400 mono= of course perfect, maybe over the top, better mate for 800.
                            price up, double up , more than triple up.
                            what can you spend?
                            all classe stuf is some time on market, many people can you make a good 2nd hand offer..... so 500 pre/2200 end should be also be possible...
                            Gerard
                            • style
                              • 1562
                              personaly in place of the cp500 (out of production of end of year, not at the level for a Cam400 & 802D!!!!) I will invest my money in the cp700 (a new big brother from the cp700 come in little time :W ):
                              the cp700
                              the CA2200 (with a eye for a second CA2200 to go in bi amp.)
                              B&W802d
                              player?
                              if you go with a cp500 to buy the cam400, you don't willl be happy with th e maplification...a amplifier like the CA2200 or Cam400 NEED a GOOD preampli :T
                              the sound from your system will be to the max performance delivered from the more thinsmaller -> Your system will sound that offers the weakest link in the chain....
                              style
                              • wettou
                                • 3389
                                CT-M600 on it's way in the Delta skin that is my dream, but first I want my room to be measured acoustically any recommendations
                                • style
                                  • 1562
                                  Hallo,
                                  Idon't know...
                                  the ctm600 with the B&W800Di during the first test does not have much of an impression ....
                                  the customer can expect many more.
                                  Maybe a ctm300 or a ct2300 , 2 amplifier with 300watt are more as enough.
                                  the new Diamont are so not hungry as watt
                                  my 803di responds very differently(powered from a CA2200) vs. my "old" 803d powered from the CA3200...
                                  Style
                                  • gerardhn
                                    • 352
                                    Style,
                                    I sold the cp 500..
                                    So can follow yr suggestion... to get cp 700...
                                    • style
                                      • 1562
                                      Hoi gerardhn,
                                      for me is the top "solution".
                                      I have more CP700 at very grood price in the last time...
                                      with the CP700, the CA2200 and a good player (Mrantz, Esoteric, the same Classe but too a oppo 8SE for movie & music is a good setup))
                                      The oppo 83se with the analog can give you very satisfaction!
                                      I have try more & more times my Lx91 (Pioneer) and the Denon 3800 in analog:
                                      the Denon with a big suprise sound better vs. the Pioneer!!! 8O
                                      and I had always think that the Lx91 was a lot better from the Denon! ops:
                                      I speak from music stereo, not movies!!!
                                      greoten Style
                                      • Blue-Eyes
                                        • Dec 2002
                                        • 162
                                        Why making each other crazy.......
                                        A CA2100 will do the trick. A CA2200 will do it better. The more power, the better.
                                        But look at your budget.
                                        There's always a bigger fish. Be real!
                                        Never drive faster than your Angel can fly!
                                        • style
                                          • 1562
                                          hoi Blue eyes,
                                          yes of course...but you have made the same with the ssp600 & ssp800.
                                          a CP700 for €. 4500 in a second hand with a little of fortune will be possible.
                                          and Hey, that a great pre! Mooi so!!!
                                          groeten Style
                                          • gerardhn
                                            • 352
                                            Style,
                                            Yes I want to spend the price you mentioned (max!) for the 700.
                                            I have also classe cdp.
                                            But if i would buy new cdp ... i would hesitate to buy such expensive cdp.
                                            We said at this forum more times... sometimes classe is overprized.
                                            (stainless steel lua with some tubes on it .... also pefect!)
                                            Groeten.
