CDP-102 problem
  • Aquarius
    • 48
    CDP-102 problem
    A friend of mine has CDP-102 with the problem reading DVD and DVD-Audio discs (after inserting the dics display says "please insert a disc"). CD playback works just fine. He has the latest firmware and MPEG software upgrade.
    Just to mention that before upgrading MPEG, everything worked with no problems of any kind.
    Is it possible to DOWNGRADE software or do you have some solution on this case?
  • aarsoe
    • 795
    You can try to re-flash it again. That is possible.
    Otherwise it does sound like a service "thing"..
    • Aquarius
      • 48
      Thanks. Any suggestion how to do it?
      • RLRB
        • 32
        classe cdp 102
        of course you can downgrade
        this weekend i will search in other computer the old firmware version and send to you via megaupload
        send me your mail in private message
        But, i dont think there is a firmware problem. the optical mechanisma teac dv28sl is as shit and fails
        how to do?? connect serial cable and classe firmware downloader, follow instructions, its easy
        bye
        • Aquarius
          • 48
          I think firmware is not the problem, but the MPEG version is. Can I downgrade MPEG software version?
          Anyway, I'm sending you mail via PM. Thanks!
