Krell Adds Auto-Room Correction To Its $30,000 Evolution 707 AV Preamp
Originally posted by mjbWhich sounds like the marketing dept. is holding it back for the SSP-900 to give us all a reason to upgrade.
On the Other hand $30,000 for a processor come on!!!
Krell has "A 32 bit dual core DSP running at 1.8 giga operations per second computes equalizer filter coefficients and applies individual curves to each of the 8.4 output channels"
Classé has two 64 bit Momentum Data Systems
- Texas Instruments Aureus DAE-77 Chip
DAE-77 Dual DSP Digital Only Audio Engine
Compact form factor dual DSP AV Receiver processor
The DAE-77 is a dual floating point DSP surround sound decoder and processing module for AV Receiver applications. The DAE-77 does not have any analog I/O and can therefor be customized to create unique product definitions
The DAE-77 supports all Dolby and DTS formats, including the newest HD formats found on Blu Ray discs. The second DSP node is dedicated to post processing, and supports leading room EQ system software.
Last edited by wettou; 11 April 2010, 22:28 Sunday.Farming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
Originally posted by mjbIf Krell can do this with a simple firmware update, perhaps Classé can too - with their "flagship" SSP-800? Here's hoping :lol:
Originally posted by wettouClassé has two [color=red]64 bit Momentum Data Systems MDS DAE-7D (7503) Module
- Texas Instruments Aureus DA710 Chip (TMS320D710A-300MHz)
>>The DAE-77 supports all Dolby and DTS formats, including the newest HD formats found on Blu Ray discs. The second DSP node is dedicated to post processing, and supports leading room EQ system software.<<
I still like certain aspects of Trinnov, despite a bad experience with a Sherwood 972.- Bottom
Originally posted by SrrndhoundIt's not the MIPs. How do you add a mic jack via firmware?Kal Rubinson
"Music in the Round"
http://forum.stereophile.com/category/music-round- Bottom
Originally posted by SrrndhoundIt's not the MIPs. How do you add a mic jack via firmware? It's just one module: Here's a link to the new dual DSP module in the SSP-800. >>The DAE-77 supports all Dolby and DTS formats, including the newest HD formats found on Blu Ray discs. The second DSP node is dedicated to post processing, and supports leading room EQ system software.<<I still like certain aspects of Trinnov, despite a bad experience with a Sherwood 972.Farming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
Originally posted by Kal RubinsonEasy. Use an external mini preamp such as the one Audyssey includes in their AudysseyPro Kit. Then, any line input will do.- Bottom
