power amp for proac response d two
  • daspaceman
    • Jan 2010
    • 28
    Just got a pair of proac response d 2, with a sensitivity of 88db.
    Do you thibk classe` is a good matching amp for proac speakers? If yes which stereo classe` power amplifier do you recommand.
    I`m interested in seond hand too.
    I think that I can get more from the speakers with a better amplifier than my current rotelrmb1075 .I will still keep the rmb1075 for centre and rear duties in an HT setup.
    Kevin Brincat.
    A/V Preamp: Rotel RSP-1069
    Power Amp : Rotel RMB-1075
    Speakers : ProAC response d two&centre,AS6Sub,Monitor.A RXFX
    Cables : Nordost Cables.
  • daspaceman
    • Jan 2010
    • 28
    Come on Classe` audio experts! I`m new into classe` gear Please help!
    • wettou
      • 3389
      Never heard those speakers beforte but you can't go wrong with 88db you should try the CT-600M that should make them sing just watch out for your wallet :B
      Or you can try Emotiva monoblocks and save $10,000
      Welcome to Emotiva Audio Corporation. Home Audio Systems, Speakers & Accessories and more. We use science to evoke the true emotion behind every note.
      • daspaceman
        • Jan 2010
        • 28
        http://emotiva.com/xpa1.shtm
        Come on! my budget is around 3000, i`m interested in second hand too
        • hifiguymi
          • 1532
          If your budget is $3K, then look at a used CA-2200. There are a couple of them on AudiogoN right now, one at $2750.00 (sale pending) and one at $3500.00 (which is a touch high in my opinion), so you should be able to find one around three grand. It is a wonderful sounding amp but I've not heard it with Proac speakers. I would think it would work well with those speakers since it's been very good on everything else I've heard it on.
          Eric
          • daspaceman
            • Jan 2010
            • 28
            Eric
            Thanks eric. Should i buy the CA-2200, will my rotel rsp1069 pre/pro be good with the classe or i would need to buy a classe preamp to go with it?
            Thanks!
            • hifiguymi
              • 1532
              Yes, yes, and yes. I personally think, as I said, that the CA-2200 is a very good sounding amp and would highly recommend it. As far as the preamp, the RSP-1069 will work well with the CA-2200 but a Classe preamp will be better. It all comes down to, just like everything else, how much you want to spend.
              Eric
              • daspaceman
                • Jan 2010
                • 28
                Eric
                Thanks hifi guy.. I will start with the amp first... then see how it goes from there. If I still want to upgrade I will buy the preamp later.
                Will the Ca-2100 be enough to power the proac speakers?
                What second hand preamp from classe do you recommand?. (want to spend around 1500) I know that lots of the class preamps have an HT bypass , ans that is good for me :T
                • hifiguymi
                  • 1532
                  I would think the CA-2100 would work with those speakers. Both the CA-2100 and CA-2200 sound very similar with the CA-2200 having more power and authority on the bottom end. From what I've seen, there are fewer CA-2100s used but they do pop up once in a while.
                  The Classe preamps that have an HT bypass are the CP-500 and CP-700. I haven't seen a CP-500 for around $1500.00 but that doesn't mean there won't be one at some point. Both of the Delta series preamps are very open and detailed. The CP-700 is a little better at micro dynamics and has a darker background but both are very good. The CP-47.5 from the previous series is pretty nice as well but doesn't have an HT bypass.
                  Eric
                  • wettou
                    • 3389
                    CA-2100 is a great amp for more humph get the CA-2200
                    • daspaceman
                      • Jan 2010
                      • 28
                      Thanks hifiguymi and wettou .. I will read some reviews on the above mentioned kit
                      I discovered that the older CP65 has an HT bypass too. do you recommand that model since it`s a little old?
                      One last important question : I live in europe, much of audiogon gear is 120V .
                      Is it difficult to set Classe gear to 230V or is it better to try and buy classe gear from europe ? Classe Gear in the USA is much cheaper though!
                      • wettou
                        • 3389
                        You can jusr send it to Classé in Europe and they will rest the voltage
                        • daspaceman
                          • Jan 2010
                          • 28
                          Good to know! thanks
                          • wettou
                            • 3389
                            Most welcome, double check with Classé first
