I know most people have the SSP-800 at this point, but hoping someone may have had this issue before with the SSP600 or 300. I just purchased some new speakers (ML) for my system so I need to recalibrate. Whenever I start auto calibration, it starts for a few cycles on the left channel and then it just stops. I rebooted the SSP as well as change the battery in the mic. Any ideals as to what is causing this problem. I hope the SSP is not faulty as the warranty just expired last week
SSP-300 autocalibration does not finish
I'm experiencing the exact same problem with my SSP-300. For the 'distance' section that is. The autocalibration feature seems to be working fine when setting the volume levels (then the signal does travel from front left to surround left).
The software version is 1.5.3. and I already performed a 'factory reset'.
Any help or feedback is much appreciated.Marantz SR7005, UD5007; B&W SCMS, Nautilus SCM1; Velodyne SPL-1200R- Bottom
Originally posted by begoodI know most people have the SSP-800 at this point, but hoping someone may have had this issue before with the SSP600 or 300. I just purchased some new speakers (ML) for my system so I need to recalibrate. Whenever I start auto calibration, it starts for a few cycles on the left channel and then it just stops. I rebooted the SSP as well as change the battery in the mic. Any ideals as to what is causing this problem. I hope the SSP is not faulty as the warranty just expired last weekFarming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
I received a new mic from Classe, but it did not resolve the issue. The auto configuration would stop after a few seconds. I did some additional digging around and discovered the problem is caused by the display timeout. For some reason, the display timeout was causing the auto config cycle to stop. After I set the display timeout to never, the auto configuration executed as expected. I guess this is a software bug. I will pass this info to Classe. Perhaps they will release a fix- Bottom
