SSP-800 OSD doesn't work anymore
  • ian1975
    • Apr 2009
    • 83
    Hello to all!
    My OSD use to display on my TV, now it doesn't work anymore. I try to setup in the OSD menu (time, event)...but doesn't fix the problem. I called Classé, they said that it's a software problem, just wait for my dual DSP upgrade and it should fix the problem.
    Any idea? anyone?
    Thanks!
    Ian
  • Maverick71
    • Nov 2006
    • 94
    Yes, that's a known issue that I believe has been solved in the latest firmware (still in beta).
    I have also experienced it. In my case, switching the unit off and on again (at the main rear switch) re-activates the OSD.
    Mav
    • ian1975
      • Apr 2009
      • 83
      Thanks Mave!
      Ian
      • style
        • 1562
        hi ian,
        sorry but I dont' have understand with the PM:
        now after the "job" that I have say to do work the OSD or no???
        give me a feed back.
        greetings Style
        • ian1975
          • Apr 2009
          • 83
          Thanks Style! your info worked very well..
          Ian
          • style
            • 1562
            Hi Ian,
            OSD work gain :T ,
            you have a set your HT on the ssp800? or only 2.1?
            what do you have as cd player?
            Style
            • ian1975
              • Apr 2009
              • 83
              Hi Style!
              I use a Rotel RCD-1072 CD player as a transport. Everything (DAC) is processed through the SSP-800. I use a 5.1 setup for movies and stereo for CD listening.
              Thanks!
              • style
                • 1562
                Hi Ian,
                OSD work gain :T ,
                Style
