I just got a pre-owned SSP-600. It has a firmware dated from 2004. I dont have a pc to upgrade but I do have a mac, running Win XP on it. My question is that can I get a USB to Serial adapter for the firmware upgrade, while running XP on my mac? Any additional advice on upgrading the firmware would be highly appreciated. Thanks.
Need help upgrading the SSP-600 firmware
Tags: None
I did an update of my ssp-300 with the mac running vista (vmware fusion).
I have an usb to serial adapter. you can choose what port it would be so i choose com2
Don't remember the cable layout, but i worked with a breakout box and it was either strait (modem cable) or crossed (null modem cable).
was very easy once connected. the installation manual on the classe site was very clear.
good luck,
Freek- Bottom
