Question for CA-5200
  • ian1975
    • Apr 2009
    • 83
    Is it 200 W X 5 class A or Class D and what is the difference? :P :P
    Thanks!
    Ian
  • style
    • 1562
    Sorry you have a new CA5200 or??
    D = digital, chip or so like that
    A = pur transistor,real power
    • Kal Rubinson
      • 2109
      Thanks!
      Ian
      Neither.
      Kal Rubinson
      "Music in the Round"
      • mjb
        • 1483
        Neither.
        What do you mean Kal?
        200w @ 8 ohms.
        Class A/B, the first 30 watts (8R) are class A - if I understand their blurb correctly.
        - Mike
        Main System:
        B&W 802D, HTM2D, SCMS
        • ian1975
          • Apr 2009
          • 83
          Thanks Mike! that was the answer that I'm looking for...
          Ian
          • Kal Rubinson
            • 2109
            200w @ 8 ohms.
            That makes it a Class AB amp. All AB amps are Class A for some minority portion of their output. It is determined by the amount of bias applied to the output stages.
            Kal
            Kal Rubinson
            • mjb
              • 1483
              Kal
              Agreed. I just didn't expect your response to be so terse. At least the OP is happy :T
              - Mike
              Main System:
              • ian1975
                • Apr 2009
                • 83
                Is the class AB amp sounds better than the class D amp?
                Is it true that class AB amp is hotter when it runs than the class D and uses a lot more electricity?
                thanks!
                • mjb
                  • 1483
                  This is subjective. Its best make up your own mind.
                  Is it true that class AB amp is hotter when it runs than the class D and uses a lot more electricity?!
                  Yes and yes.
                  Class D uses high frequency switching technology, so its not a "classic" amplifier design. Some people are OK with that, others are not.
                  - Mike
                  Main System:
