Does anyone encounter that one of the pairs got hot after playing a few songs and the other just remain warm on the surface? Is that the problem of the bias? Anyone can help? Thanks!
need help for the CAM-400
I have had my Classe Cam400's for almost a year and I am amazed that they never get hot. This is even after running them hard for a long period of time. Now my 5200 amp from Classe is hot all of the time!
I would check to make sure that you have it hooked up correctly?- Bottom
I also had them for almost a year and they performed fanstatic in the past. I had followed the instruction in the manual to check all my other components, they are perfect all right. So I think the problem should be the Classe , they even shut down suddenly in the middle of the listening. Really frustrated.
Peter- Bottom
Originally posted by peter_pI also had them for almost a year and they performed fanstatic in the past. I had followed the instruction in the manual to check all my other components, they are perfect all right. So I think the problem should be the Classe , they even shut down suddenly in the middle of the listening. Really frustrated. PeterFarming looks mighty easy when your plow is a pencil, and you're a thousand miles from the corn field."Dwight D. Eisenhower- Bottom
Peter
Originally posted by hifiguymiHave you tried switching the amps around so the the one that is getting hot is running the other speaker? You may have something going on with one of your speakers.
Eric
Thanks Eric, I was barking up the wrong tree. The culprit is one of the speakers. Thank you everyone for your information.- Bottom
