Classe Audio Delta CP-700, 2 x CA-2200 and CDP-202.
Tags: None- Bottom
fredBelgium
Very Nice Setup Indeed!!!
Great pictures & slideshows on your site also. I would be very interested in hearing your comments on the differences you experienced between the vertical bi-amping & horizontal bi-amping as shown in the above diagram versus not bi-amping at all. I'm especially anxious to hear what lead you to describe the vertical connection as "Good" and the horizontal connection as "Not Good"
Wow! It must have been a real treat to have listened to 802D's, 801D's & 800D's in your own environment. If only I could have been a fly on the wall during those sessions!
Enjoy!!!- Bottom
Hello D-bucket,
Vertical Bi amplification brings much energy to the system. With the inversse of horizontal Bi amplification. On 802D it to me forever seemed that Bi amplification would be necessary with a CA-2200. On the other hand, with 801D and 800D it is really what it is necessary to do. Vertical Bi amplification brings a better balance on the distribution while running. Balance is really perfect. Whereas into horizontal an amplifier under is exploited and the other on exploited. With listening that is understood by a ventilation and an obvious precision. The unit is more directing. Attacks franker. It is more realistic for which likes to listen to Jazz in room.
Fred.- Bottom
Interesting, thanks Fred, I do appreciate your response to my questions. I had raised a similiar question in the B&W thread Unconventional Bi-amping B&W 802D - WOW last year and the consensus then also seemed to agree with you that the vertical bi-amping connection was the preferred connection method when using 2 identical amps.
Originally posted by D-bucketWhen passively bi-amping a pair of b&w 803D's (or any of the other 800 series) with 2 identical stereo power amps, are there major advantages or differences between these two connections?
Connection 1 - (one 2-channel amp dedicated to each speaker)- amp #1 - one channel connected to HF posts of left speaker & second channel connected to the LF posts of left speaker
- amp #2 - one channel connected to HF posts of right speaker & second channel connected to the LF posts of right speaker
Connection 2 - (one 2-channel amp dedicated to each frequency filter)- amp #1 - one channel connected to HF posts of left speaker & second channel connected to the HF posts of right speaker
- amp #2 - one channel connected to LF posts of left speaker & second channel connected to the LF posts of right speaker
I agree. I use Vertical amp using two 5100 on 2 802D. Other channels are used for Home theatre
Vertical bi-amp gives a better stereo image than horizontal one. I do not know why.
I do not think that the bi-amp is required by the 802D. In my view it is much more linked with Classe’s amplifier behaviour with 800’s. Perhaps, other amplifiers could have a better behaviour.
I also think that B&W have to take care with the load. B&W 800 requires expensive amplifier because they require a lot of current (low-cost amplifiers are tuned for 6-8 Ohms mainly resistive loads, you have to pay for current). For example, the 803D offer a module as low as 3 Ohms and, generally the load is very complex, meaning that current and voltage are not in phase. As our ‘power’ amplifiers are voltage amplifiers, any phase shift increases current requirement. High Currents also switch amplifier from class A to Class AB mode.
Yann – Paris, France- Bottom
Hello Gerald,
I do not have any cable in Y because the preamplifier CP-700 has 2 X 2 exits for the power modules.
You can see that here on the 2nd image of the Analysis cables… picture 9...
Frederic.- Bottom
Originally posted by gerardhnFred,
I see it. ! Very unusual to have that. 2* 2 bal out. My CP-500 doesnot have that.
It is for me one of the large advantages of the CP-700. That makes it possible to evolve/move in time without having to change préampli.
Good day with you,
Frederic.- Bottom
