I've had a few inquiries from folks about Parts Express new Dayton Reference series, with aluminum cones, sheilded magnets, phase plugs, cast frames, etc., especially since Mark K got some very nice test numbers on an early prototype he evaluated.
Specifications: *Power handling: 80 watts RMS/120 watts max *VCdia: 1.5" *Le: 1.0 mH *Znom: 8 ohms *Re: 6.4 ohms *Frequency range: 30-2,000 Hz *Fs: 29 Hz *SPL: 88.4 dB 2.83V/1m *Vas: 2.37 cu. ft. *Qms: 1.80 *Qes: .47 *Qts: .37 *Xmax: 7 mm *Dimensions: A: 8-3/4", B: 7-3/8", C: 4".
Long-excursion motor and suspension for strong bass performance
Subtle yet high-tech look makes a bold cosmetic statement
Ultra-low stray magnetic field allows extremely close proximity to CRT's
Designed and engineered in the U.S.A.
SO, just for the record, I have ordered a pair to evaluate. There's not a lot of info posted on PE, just the T/S parameters, no sweeps. But it is pretty promising; for example, Xmax is 7 mm, while it still has pretty decent sensitivity, 88.4 dB. And that's for an 8 ohm driver (RE of 6.4 ohms).
The 64 dollar question, is would it be adaptable to an M8a based design with a little effort? Mark K measured some VERY respectable distortion numbers; in the area below 1 kHz, this puppy runs with and past the big dogs. Forget your Seas W22.
So, in our never ending quest to bring excellence for cheap, I'm going to take a closer look. This pair may wind up in my M8ta's.
~Jon
~Jon
