Hi All,
I recently ordered a new pair of C173-6-090 to replace my older set (one of the pairs started to make strange noises depending on how the screws are tightened on it). To my surprise, the new one is quite different from the older, despite the same model name.
From outside, the biggest difference is the magnet system. The new magnet is more rounded, and lacks the big magnet vent hole. Instead the new has 7 tiny-tiny holes on the back, but I'm not sure if they're really opened, actually. Moreover, the glue used for the anti-resonant cut-outs are also different, and the cone seems to have a very thin slightly shiny back-coating, too (I think that's not the case with the old one).
You can see the old version on the Madisound web page for example, the new one on the Accuton site.
Frequency responses and other graphs do seem also different, and I'm not exactly happy to see this going under the same type number.
Does anybody have some experience with those, can I just blindly drop-in replace the older ones, or should I adjust the crossover (I guess this is a yes, just would be nice to hear the opposite )?
igy
igy
