SoundEasy Dummies guide available??
  • penngray
    • 341
    Is there any links that will show me the step by step of getting SoundEasy up and running?
    Something with the following....
    1. Set Mic calibration
    2. Do soundcard calibration
    3. Simple 2 way measurement and XO examples.
    It would help me get running a lot quicker with SoundEasy. I was going to measure an older TC2000 woofer (Im selling it and I need the T/S parameters) with it today but nothing is intuitive at this point.
  • brent_s
    • 89
    I think I've seen links to some free guides online (linked from Techtalk maybe?), but Zaph links to this guide in his on SE setup description.
    -Brent
    • ttan98
      • 153
      soundeasy guide from J.K. Go to this site:
      musicanddesign.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, musicanddesign.com has it all. We hope you find what you are searching for!
      See top left hand corner. I have the earlier version. Quite good, helped me when I was learning about speaker design and using this s/w package. Recommended.
      • jkrutke
        • 590
        John Kreskovsky's tutorial is well worth the $11.
        Also you might check out http://chadgray.info/soundeasy/.
        Zaph|Audio
        • penngray
          • 341
          I did purchase John K's tutorial!! Thanks, Its helped me get the calibration files created but now I can not figure out why my measurement of a new CD (TAD 1402) looks strange.
          Sound Easy measurement.
          vs ARTA measurement
          What did I do wrong??
            • 571
            Check your probe set-up. You should see a "reference" and "input" impulse. I don't see an "input". The blue is the reference, I believe you are just picking up noise for the input judging by the 100db added to the input. The bar graph should also show some level.
            • penngray
              • 341
              Yes, i added dB to just see the SPL plot.
              What do you mean by "Probe setup"? Im getting an IR plot when I run MLS and my measurements setup (ECM8000 + m-audio mobilepre) is working because ARTA and HOLM have zero issues.
              back to reading more of the tutorial. I think I understand what you are saying about the "In" levels but Im not sure how to increase them. I remember in the calibration setup I had to increase them and I had them set properly. I have not changed anything since then so Im definitely confused.
              Thanks!
                • 571
                Your set-up should be as shown below:
                Left-in is the reference and right-in is the input.
                Here is a screen capture from the manual to show how it should look.
                • penngray
                  • 341
                  Thanks, I did wondered about that right input. I know during loop back everything worked out nicely since both left and right inputs had been connected.
                  With HOLM, ARTA, etc I only need the Left output going to my amp and Left input connected to my Mic ( the mobilepre soundcard has phantom power). Clean and Easy.
                  Im definitely still confused on what to connect to the right input for measuring a driver. I could connect the mic to the right input instead and leave the Left input disconnected??
                  I might just run HOLM, save the data, import it into SoundEasy and not worry about SoundEasy requiring "special" connections.
                  • penngray
                    • 341
                    haha, So SoundEasy is looking at the right Channel for the mic measurements. Im now getting a good FR plot.
                    My "ref" signal and IR does not exist now though since I have nothing connected to my Left channel. Does that matter??
                    Thanks for helping!
                      • 571
                      It's not difficult. SE needs a reference so the left input channel should be connected to the speaker terminal through a voltage divider and the mic preamp connected to the right input.
                      • penngray
                        • 341
                        what if I do not want to build a voltage divider box and do not want to connect anything to the left channel? Does that screw up soundeasy measurements?
                          • 571
                          Both channels are required. The reference provides the reference signal for amplitude and phase and it automatically calibrates out the response of the amplifier and sound card.
                          • JonP
                            • 690
                            Looks like you got the overall basics answered. Play with your sound card in and out levels... typically, line in all the way up or nearly, adjust output for good signal level. You want to be pretty close to the top of the meters, without hitting the red. Better signal to noise ratio.
                            And, another important point when you have both channels of input showing up, is that they need to be the same polarity. A checkbox in the setup window will invert polarity if you need to.
                            Be very careful if you're trying to run without "probes" or some attenuator, if you have an external amp. It's very easy to smoke your soundcard otherwise.
                            • penngray
                              • 341
                              Thanks Jon!
                              Im going to run measurements with the probe setup. I will read help files to figure out if input channels have the same polarity.
                              • Randy Swain
                                • Jun 2022
                                Hi I hav e soundeasy 10 upgraded to 14. I am not able to see full size of driver editor window. Any help? Thanks
                                • augerpro
                                  • 1866
                                  Is you windows scaling over 100%?
                                  ~Brandon 8O
                                  DriverVault
                                  Soma Sonus
                                  • Reet
                                    • Dec 2007
                                    • 524
                                    Screen resolution? Not much info provided here to work with...V14 is old, like 14 years or so, SE is at v28 now, and FWIW it looks like the "official support" has just moved to groups.io:
                                    This is a group dedicated to the use of software created by Bodzio https://www.bodziosoftware.com.au/
                                    As a modern alternative, VituixCAD along with REW or ARTA provide a much more user friendly experience.
                                    https://discord.gg/h5SuNKDJfx
                                      • 1532
                                      Of course, there are those who's Force intuition lead them to tools like Fuzzmeaure and Clio or Pocket Clio- the latter is multi-platform, and very reasonably priced considering it includes the audio interface, software, and microphone.
                                      • Reet
                                        • Dec 2007
                                        • 524
                                        Clio pocket is only a single channel system though, no? Need the full Clio package for dual channel measurements to match the functionality of SE or ARTA.
                                        • kimmosto
                                          • 589
                                          All CLIO programs and interfaces are able to measure timing without software functions and external loopback connection required with measurement programs for generic audio interfaces.
                                          • Reet
                                            • Dec 2007
                                            • 524
                                            Interesting, thanks for clarifying. I had looked at the Clio system a few years back, but it wasn’t clear to me reading the documentation other than the fact that the pocket clearly had a single input so I had assumed it had the same limitations of a normal audio interface.
                                              • 15284
                                              The Pocket Clio Survival Guide and Joe D'Apollito's review may clear up some confusion- but there's a lot of stuff in that little box that is not documented in a block diagram. Note the use of an internal calibration procedure to complete before any measurements, as well as recording the specific sensitivity for the test microphone, which is provided for each microphone shipped.
                                              While I wouldn't give up my ACO Pacific mics, pre buffers, and MOTUS interface, there's a lot to say for what the Pocket CLIO can do. Contrast and compare will be on my agenda after things settle down. Of course, part of my interest is because it includes software for the MacOS platform, and a 64 bit version that even runs well under Rosetta II emulation on M1 Macs.
