Which testing gear (measurement) ???
  • NyxOne
    • 184
    Hi everyone,
    i want to start taking my own measurement and after reading a couple of thread around here i got a question or two. To be honest, it's more about what you would suggest as an ideal "initial - DIYer" setup. I can't set my mind...
    -- Reference --
    -- Reference --
    Those are the options i'm considering
    1. ECM8000, MOBILEPRE USB
    2. ECM8000, A good sound card (Audigy maybe), a Mixer (UB-502 or UB-802).
    Note1 : I plan on using LspCAD for design and justLMS for measurement (an maybe something else later).
    Note2 : I just bought a WT3 so T/S and impendance will be taken with it. I don't know if it can do a difference in the process of selecting a setup ...
    Thanks.
    Charles D.
    • 10931
    Either option works fine.
    I have both, neither offers a significant advantage.
    Note that you don't want the UB-502 since it lacks phantom power
    • NyxOne
      • 184
      Thanks for the reply,
      i think i gonna go with MobilePRE & ECM8000 solution since it will cost less that way.
      Thanks.
      Charles D.
        • 10931
        That's the most 'portable' and least hassle way to go..
        • Nemophyle
          • 40
          day of the tentacle
          • TacoD
            • 1078
            I got good results with ECM8000 and UB 802 (with phantom supply for mic) and JustMLS
            • NyxOne
              • 184
              ThomasW : That's what i thought. And you can use it with both a Laptop and normal/standard computeur which is not the case with a normal soundcard.
              Nemophyle : I didn't think someone would recognize it!
              TacoD : It's fun to know that there are some people around here who use JustLMS for measurement.
              Thanks everyone!
              Charles D.
              • Gir
                • 309
                I wasn't going to bring up, but since someone else has, I absolutely love that game! Ohhhhhh the memories...
                BTW, I'll probably be going with the same setup once I get a few pay checks under my belt.
                -Tyler
                • NyxOne
                  • 184
                  Hey guys, i just wanted you to know that i bought my ECM8000 and MobilePre today! YEAH!
                  But honestly, i still a few questions i'd like to ask like how to setup my MobilePre correctly and what is the ideal or maximum cable (XLR) length between the soundcard the Mic?
                  Any of you have a source/site that my help me with these questions ?
                  Charles D.
