Using slots for ports
    • 16507
    Why is it that you seldom see anyone using a slot for a port? About the only reason I could come up with was that when using a regular tube you try to keep the openings one diameter away from any side walls which isn't as easy to do with a slot but there must be another reason I'm missing?
  • cdwitmer
    • 136
    A lot of folks like Onken enclosures. Don't those qualify as slots?
      • 8938
      Pratt, TL's use a "slot".
        • 10931
        They're a pain to calculate accurately. They're a pain to build in comparison to using a piece of PVC pipe. And it's almost impossible to create flares.
        Other than that, they're great :wink:
        • Jerry Pease
          • 37
          I feel your pain man!
          JP
          • David R.
            • Apr 2003
            • 90
            They're a pain to calculate accurately. :
            How so? If the area of the mouth remains the same, then the length stays the same (For the same tuning).
            I agree though, a length PVC pipe is easier, and flares are nice
              • 10931
              How so? If the area of the mouth remains the same....
              My bad, I didn't make myself clear. I meant with regard to integrating them into the design of the box, Not actually calculating area.
              • RonS
                • 102
                I once did an MTM design with a slot port. In that case, it was quite easy to incorporate, and had the added benefit of acting as a great side wall brace. I located the slot port directly behind the tweeter. As someone mentioned, if the mouth area is the same as a tube vent, the length should be the same as well. If you want to do a flare, a 3/4" flare is easy assuming you are using 3/4" material for the brace. You can flare both ends as well. Bigger flares could be built with some "backup" material on either end I suppose.
