NORTH D28-06S tweeter
  • BrianJD
    • 21
    "NORTH D28-06S 28mm Silk Dome Tweeter - a 1" silk dome designed by George Short, also a North Acoustics exclusive. The D28 is unique in that it is the only tweeter in the world to incorporate a Faraday Sleeve into its motor structure, resulting in the lowest distortion ever measured in a dome tweeter. 1mm peak-peak excursion, a low resonance, high power handling, and 92dB sensitivity. "
    $140./matched pair
    Click now and see best headphones, headsets and earbuds in 2024 . Our expert authors review top headphones, headsets and earbuds.
    This seems like it may be a very good tweeter for a good price.
    Has anybody had any experience with it?
    I may use it with some PHL 1340s I have, also thinking that it might be a good match with the Extremis 6 as well.
    Any opinions?
    • 15284
    Interesting design- seems to combine some of the best qualities of the lower line Seas Excel tweeter and Scanspeak soft domes. 28 mm will result in a somewhat narrower dispersion in the very high frequencies, but this looks like a robust part, adaptable to many design requirements- in fact, with an adjustment for level sensitivity and slightly different LF zobel, it would probably work well in the M8 MKIV speaker or the Arvo Part, as this is also a four ohm tweeter. That's where part of the sensitivity comes from.
    Thanks for bringing our attention to this. I buy some crossover coils from George, but haven't looked at his tweeter offerings; this one's been delayed a while, if I remember correctly.
    Now, just to speculate, I bet you could make a pretty nice MTM with this tweeter and the Adire Extremis mid woofer, hmmmmm?
    ~Jon
    • BrianJD
      • 21
      Pure speculation on my part but I think its a modified Usher 9950.
      I'm gonna order a pair.
      I realize this would probably be at the bottom of your 'to do' list, but
      if you'd like, I can send them to you for testing in your designs.
      I wont be ready to use them for awhile.
      If it works out, I'd like to try it in the M8 MKV :lol: speaker.
        • 15284
        If you have any way to test frequency response and impedance, I can use that data for crossover design. Otherwise, if you'd like, I can test them- probably no sooner than the 2nd half of October, as I'm going to Singapore on business the end of next week.
        They seem like a good value, considering the construction quality, design features, and price. I have some Peerless HDS woofers I've been planning a small two way for a friend; these would undoubtedly be very nice in that system, also.
        Jon -
        - in Houston tonight, Minneapolis tomorrow night, and Indianapolis after that!
          • 1345
          Jon, I NEED to SCUBA in the Caribbean or I'm going to go over the edge with this job responsibility crap. Just transfer a pile of frequent flyer miles to me - you'll never miss 'em. :W
            • 15284
            Uhh, Hank, what was that Frequent flyer account #, on which airline?
            I feel the same way about getting out to Colorado, but have about the same luck.... :cry:
            ~Jon
            • RogueAngel
              • Jun 2002
              • 69
              Well, I've been using a pair since May of this year and they continue to impress with an open natural sound with great imaging.
              Pictures can be seen here: Gabrielle
                • 1345
                Hmmm...could these possibly lure the Poohbah's away from their "only metal domes will do" thing?
                  • 10931
                  My understanding is that Jon will have a couple for testing purposes. From George's published info these appear to be very good tweeters
                  However, we like the 'sound' of metal domes too much to switch......:wink:
                  • Ten 99
                    • Apr 2004
                    • 133
                    I used to think that metal domes sucked, because most of them I had heard were very harsh and bright. I have since heard a few of the nicer ones out there, and I have to agree that they can be VERY nice without being fatiguing and shrill. Of course a lot of this can have to do with the x-over as well. I think that my ears have grown a lot (dumbo eh?) with regards to what sound CAN be like, versus what I grew up thinking it was supposed to be like. I still prefer the average soft dome to the average metal, but there's something to be said for the higher end metal. I have yet to hear a higher end soft dome like the millenium.
                      • 15284
                      You know what they say about it's how you use the tool, not just the tool itself.
                      OTOH, a bad metal dome tweeter (some cheap ones I tried once from MCM) can be REALLY BAD, in the sense of high Q resonances, whilest a similarly bad soft dome tweeter will just be mushy and fizzy, maybe not as annoying to some folks.
                      The ss9800 doesn't display the typical metal dome "vices", unless you pair it with some poor electronics- it is both a bit more tranparent and smoothin the presence region (IMO), and sweeter in the top, than say, a Focal TC90 or 120. Lower distortion? I think so- the Focal is really optimized for high efficiency and response above 2 kHz. Most of the best tweeters I like have more Xmax, and smoother down below 1 kHz.
                      ~Jon
                      Greetings from Singapore
                        • 15284
                        OK, I'm clearly going to have a busy weekend coming up- besides the Dayton RS225-8's, I've got a pair of NorthCreek D28's now, to take a look at- on loan from Brian, while he moves cross country. Another set is in route for further investigations, and Mark K has agreed to do some linear and non-linear distortion measurements with Praxis.
                        ~Jon
