Semi-DIY speaker wire
  • Pez
    • 472
    Going to give this a try:
    Link deleted by Admin
    Basically its using some Ultralink 14 guage 4 conuctor in wall speaker wire and combining 2 pairs for the + and the other 2 pairs for the -. I want to dress it up but not sure what size techflex to use. Also want to put some heat shrink tubing on the 2 combined conductors and over the ends of the techflex. Any suggestions of sizes would be very helpful.
    You can get the same wire a lot cheaper from our friendly sponsor, Parts Express. Click the banner above and search for part # 100-768 . They have all the other parts you will need as well.
      sacred trinity of L/C/R: Inductance (L in henries), Capacitance (C in farads), and Resistance (R in ohms).
      Pretty funny, he spends 1/2 of the article blabbling about the importance of stuff, then never bothers to measure them. :roflmao:
      • Pez
        • 472
        Had I not already had all the pieces I would have purchased this stuff from PE. When I bought my last set of speakers the store gave me a killer discount on speaker wire, it just so happens to be the same stuff in that article. I already had some banana plugs laying around so I am ready to "dress up" the cable. I will be getting the techflex from PE, just need to figure out what size.
        • Ten 99
          • Apr 2004
          • 133
          What is the diameter of the wire you've got there? 1/4", 3/8", 1/2" ??? That will be the determining factor. Note, the techflex will adapt within some limits to the diameter of the cable it is covering, but if you're using 1/4" techflex to cover 1/2" cable, understand that the weave has to 'open up' a bit to accomodate. This just means that the techflex becomes less opaque and the color of the cable jacket shows through more.
          • PiDD
            • 240
            I also read the article way back. I had Home Depot 12g special and decided to try this. It was cheap enough $0.70/ft cdn.
            I really liked the new sound.
            I dressed it up with 1/4" flex mesh but that is too small and stretches too much and you can see the cable underneath. I would go 3/8" next time. For heat shrink I went 1/2" for the cable and 3/8" for the banana plugs.
            Hope this helps.
            Rob
            • Mr. Shrink
              Deleted as sales promotion from Vendor or Vendor associate, Admin
              Mr. Shrink, while you may be shrunk, you can't promote products here. Your account will be deleted unless you cank think of a non-industry association for your username. Please email if you can think of a name that meets guidelines. Admin.
