for some reason, I want TWO!
  • Bent
    • Sep 2003
    • 1570
    Greetings again.
    I thought I'd dare ask, what 15 inch driver is available in a dual VC version with the nominal impedance (per VC) = 4 ohms?
    I can't seem to get it out of my head that 2 tempests in a tall slender sealed box (ok, as slender as a 15" driver will allow) would work well to provide effortless (and cost effective) bass,and with the two drivers being "essentially" co-located, I'd have no phasing issues between the two drivers - and be an interesting conversation peice as well... 'cept the Tempest is a dual 8 ohm unit... there is no way to wire all four voice coils to allow a final combined impedance of 4 ohms - so I'm wondering if there is a driver like the Tempest, but in daul 4 ohm variety???
    (this all started with me thinking I'd best utilize the power of a typical plate amp that works well driving a 4 ohm load... am I way out to lunch here?)
    • 16507
    There's no reason why you have to use both VC's. The tempest will run just fine off one VC per driver allowing you to keep the final resistance to 4 ohms. all four of my tempests in the IB are running on one VC for this very reason...QTC changes a little and power handeling drops in half but that won't be an issue with a plate amp.
      Any reason you can't use a pair of SVC 8 ohm drivers wired in series?
      • Bent
        • Sep 2003
        • 1570
        Thomas... are you sure of what you said... 2 SVC's in series (to equal 16 ohms???). :E
        In all seriousness, I would try two 8 ohm units in Paralllel, but I can't think of a manufacturer I'd like to support that is as cost effective as our friends at Adire. Any recomendations? I would have no trouble with a classy looknig box that stands 36" tall.
          • 16507
          oops never mind.
            Oops ... yes parallel. Aalzheimers moments are sooo embarressing .... :W
              • 16507
              Thomas time to put away those aluminum pots :W
              Any comment on why he can't just use one VC?
              • Bent
                • Sep 2003
                • 1570
                I guess I could experiment with a dual variable potentiometer to vary the Qes parameters of the system, but I'd have no idea what to look for....(sound quality, that is).
                  It's too late Andrew ...................... :rollhead:
                  Of course he can. I think it's a bummer to lose the output (-3dB for each driver) by leaving one VC open.
                    • 1345
                    "Oklahoma, Oklahoma, Okla, Okla, Okla - homa!"
                    -Ruprechkt
                    • Bent
                      • Sep 2003
                      • 1570
                      ???? :B
                        • 1345
                        From Steve Martin's temporary character within the movie, "Dirty Rotten Scoundrels" A funny movie. :T
                        • taz13
                          • 930
                          Just have to have two!
                          If you have the number two in mind then just make two towers and drive them from one plate amp and all voice coils are in cct. parallel vcs and series drivers with the towers in parallel, might sound nice.
                          The day is not complete if something new is not learnt.
                          Taz/Rick/Richard/Ricardo
                          • Bam!
                            • Jan 2004
                            • 2458
                            Originally posted by Hank
                            From Steve Martin in "Dirty Rotten Scoundrels" A funny movie.
                            Even with the explanation...I am still :blink: :blink: :blink:
                            :lol:
                            Got a nice rack to show me ?
                            • Pat
                              • 1637
                              Hank, I "get it" :rofl:
                              No worries
                              The other guys obviously haven't seen the movie
                              Ben, are you stuck using the plate amp or is there a possibilty of just using a 2 channel amp.
                              I am using an old yamaha 2 ch. amp to power my 2 shivas.
                              The dual 8 ohm vc's are wired in parallel on each driver, so I have a 4 ohm load on each channel. The amp puts out around 230w @ 4ohms and I have never been lacking for output.
                              Just tossing out another idea...
                              Pat's Page
                              • Bent
                                • Sep 2003
                                • 1570
                                no real affliction with the plate amp, I just thought it might make it a bit more desirable when "re-sale" time comes around.
                                seems I need a new remote control first... sigh.
                                  • 16507
                                  Ben I'd go for the seperate amp as well..much easier to work with and you'll own the amp for several subs if you get a decent one now.
                                  • Bent
                                    • Sep 2003
                                    • 1570
                                    SOlD, I just recently saw a bigger (600 w/ch Carver 2 channel on some local B&S) amp for about 300 bucks.
                                    • Pat
                                      • 1637
                                      Congrats on the new amp!
                                      Pat's Page
                                        • 16507
                                        Damn that's a great find...and local too! At least now you won't have to worry about powering your future DIY subs...well unless you go nuts and buy a couple of tumults and try to LT them into a shoebox
                                        • Bent
                                          • Sep 2003
                                          • 1570
                                          I can't find the ad anymore... I don't know if he had a buyer, so I'll put in a WTB and see if he notices it.
