Need T/S parameters for Audiomobile Mass 12 driver
  • Eric S
    • Sep 2000
    • 175
    Hi Folks,
    I'm a long time lurker but an infrequent poster who is hoping someone can help out. It was the posts by ThomasW years ago that convinced me that my new sub just HAD to feature an Audiomobile Mass 12 driver :B and now I can't find my spec sheet and the company appears to be defunct. :cry: The specific driver I have is the Mass 2012 S24 (purchased in 2000), dual voice coil, 12 inch driver, 4 ohms per voice coil.
    Could someone please post the full set of specs for this driver for me?
    Thanks!
    Eric
    My DIY Theater Projects
    • 16507
    Here's whats in the WinISD driver database...
    [Driver]
    Brand=Audiomobile
    Model=MASS 2012 S24
    Manufacturer=
    ProvidedBy=Janne Ahonen
    Comment=
    DateAdded=20020401
    DateModified=20020401
    Qts=0,418
    Znom=2
    Fs=22
    Pe=650
    SPL=85,41
    Re=1,9
    Le=0
    fLe=0
    KLe=0
    BL=10,85081
    Xmax=0,0244
    Cms=0,0002594
    Qms=5,8
    Qes=0,45
    Rms=4,8079
    Mms=0,2017
    Sd=0,05
    Vas=0,092
    Dia=0
    Vd=0,00122
    no=0,002117
    Dd=0,2523
    EBP=48,89
    numVC=2
    Hc=0
    Hg=0
    SPLmax=110,54
    SPLmaxLF=102,29
    USPL=91,66
    alfaVC=0
    Rt=0
    Ct=0
    gamma=53,78752
    Rme=61,96844
    Mpow=7,872
    Mcost=0
    c=343,68
    roo=1,20095
    • Eric S
      • Sep 2000
      • 175
      Thanks, Andrew! :T When I last used WinIsd, they didn't have the Mass driver in their database. I've since upgraded my PC and my own WinISD entry for this driver was lost.
      Looking over the specs, I wonder if they've changed between 2000 and 2002. I thought I remembered a moving mass of something like 160g and BL closer to 20... hmmmm...
      Eric
        • 3791
        It looks like you may need to to some units conversion on those numbers. At a glance, it appears that Xmax is in meters, Mms in kilograms, Vas in cubic meters, etc.
          • 10931
          Here's a website with some Dumax testing parameters
          • Eric S
            • Sep 2000
            • 175
            Thanks, Thomas! The number for the single voice coil driver are fairly similar to the DVC. From a number of sources, I have been able to put together a list of the T/S parameters for this driver.
            Audiomobile may be defunct, but its still an awesome driver!
            Eric
