Hello all, I have 2pcs DT300 Sub amps and want to build 2 subwoofers for stereo use. I want small SEALED(60 LITERS MAX) boxes that will work low. The following sub are available to buy, 1: adire shiva 2:emminence LAB12 3:ADIRE DPL12 and possible the TC2+ which will you go for, and what box size will fit.Room size is 13 by 14ft and 8ft high.
Advice on new sub direction
The DPL 12 has the lowest distortion and T/S parameters favorable to the approach you want to use in a sealed box.
I suggest you down load Unibox and run the parameters yourself for the drivers you're considering; this will give you a lot better feeling for what you're getting into.
The only other driver I'd suggest adding to your list for evaluation is the TC-Sounds TC2+, available from O-Audio. I'm using it in a dipole design, but it would work fairly well sealed, also. Small price premium, at $165. Very low distortion in the first +/- 10mm of travel.
Jonthe AudioWorx
Just ask Mr. Ohm....- Bottom
Other considerations are that a chunk of your 60L will be taken up by the plate amp and driver. Second if you want to play really low, the only way to do that with such a small box is to use a Linkwitz transform circuit. These generally must be custom built. Third use of drivers with a lower Vas might be a better option. The newly available BluePrint 1203, or Stryke AV12 should be considered.
