4 way active mid/main field
  • mischa
    • 7
    At this moment iam building a 4 way active mid/ main field . Just one of the first pictures
    Parts :
    vifa 25-cf-300 carbon fiber .. 2 pcs
    vifa DM 760 dome mid range
    vifa 17-wp-200
    xt300 ring rad.
    Hypex 4 way active amp .3 band parametric eq , level controlles 24 db . r .
    iam not realy sure aboud the x-over freqencies but mij first guess wil be 180/800/2500
    The hypex module isnt yet in tha stores but it wil be out in aboud 6 weaks . they also .
    I someone nows another 4 way active build in block please inform me !
    wish me luck
  • mischa
    • 7
    inside
      • 15284
      Nice cabinet work, Mischa!
      Do you have measurements of the drivers response in the cabinets yet?
      This might be a big help in deciding what response profiles to use with your active crossover. What's your plan to get to your desired in room response?
      Best regards,
      • mischa
        • 7
        becous its an active system i can set any x-over freqency i want . as soon as i have the amps ill go to a (( dead room )) there iam going to set driver levels etc
        I realy would like te advice hypec amp modules . We compared a pasive unit whit brystol amps to a hypex module. hypex was way bether ..
        We design and manufacture Class D power amplifiers, power supplies, DSP solutions and plate amplifiers for the HiFi, High End and Pro Audio industries.
        • mischa
          • 7
          the active 4 way amp has for each amp ( 4 pcs ) a level controll a subsonic filter you can bridge the amps so 3 way whit 2 amps bridged is also possible also a 3 band parametric eq on it .
          it shoud be more then enoug to setup some personal preferences in a studio .
          its a new product . they also have a small 2 way amp soon whit a fixed active x over of 2.5 khz its going to be around 90 dollars a pcs ( realy nice for rear speakers etc )
            • 10931
            How do you intend to deal with issues such as baffle step compensation if you use the Hypex amps?
            • mischa
              • 7
              the hypex amps have a 3 band parametric eq .. there is a hi mid low boost/decrease , you can select freqency and the notch . so in other words full parametric . All drivers have there own level pot
              its never perfect . but its always bether then a passive x-over. and the demping factor is above 1000 so iam sure its going to sound just great
              and if i dont have enoug controll on the freqency response in my studio ill buy a behringer active 4 way 19 inch unit and hook it up to the hypex amps . then you can even do a sweep in your room and the behringer will set things as flat as possible ...
              i have to point out that all the tech talking is to mutch aboud specs and math . i do most by ear its way more sensitive as a mic
              If i dont hear anything anoying in a x-over freq its al right
              • mischa
                • 7
                i once build a 4th order Linkwitz Riley passive filter to my ears a 1th order sound more natural . the only problem was the BIG x-over bandwith
                4th order Linkwitz Riley active 24 db oct is way bether pure controll on your drivers .
                maybe someone would like to try a hypex amp on the diy speakers on this forum and do some analizing
