Jon,Thomas, others....
Jon, I have been reading with interest your posts both here and over on the Madisound Forum, in regards to your methodology of choosing the correct drivers for your projects. You consistantly bring the importance of the impedance curve into the discussion....most importantly, looking at the kinks, bumps, etc.
After reading your latest post on Madisound, I looked at the Imp. curve of the Audax HM210Z12 (I have 4 of them sitting on the shelf). The have quite a large hump at centered around 375 hz. This shows itself in the Freq.response curve as a large 3.5db dip from 225hz...ending at around 500hz.
Am I too surmise that this woofer would be best used below the impedance kink...ie, below 375hz? Is this impedance kink (which is rather large compared to other woofers I have looked at) an energy storage issue? A cone mode? ?? What are the implications of using this woofer above 375hz?
I am not requesting a specific 'design' question....just looking for a more broad based understanding of this issue.
On a separate note...Another interesting observation is that rigid coned woofers, at approximately half the frequency of their major breakup region...they have a spike in their distortion products. For example, on the Excel W15, the major breakup region is around 6K...but, distortion spikes in the 2.5-3k range. Which would cause a designer to consider crossing over these types of woofers with steep slopes at a minimum of half of their major breakup frequency. Would this be another 'guideline' (albiet, broadbased) when considering various drivers?
I am a fan of rigid drivers (both tweeters,mids, woofs) and am looking to get better at my hobby. Thanks for anything you can offer.
Have a good weekend guys! :B
Steve Paul
Steve Paul
