I started to build the Amigas from Paul Carmody
He says in instructions:
That was pretty clear until I realised that the cabinet is so narrow. The internal width of the cabinet is 165mm. I have a 50mm thick foam, so if I cover the sides, it leaves me 65mm of free space between the walls, which seems a bit strange for me. Even the port tube will almost touch the foam from the sides. And the "wad" of stuffing which goes to the lower 1/4 would be very small indeed.
So please could you, more experienced builders share your thoughts? What is the ideal thickness of foam in regard of the internal dimensions? What is acceptable?
Should I find a thinner foam? I think I've seen a variety of 25 - 30 mm. Would that be OK?
The interior walls of the enclosure need to be lined with some sort of convoluted foam or BlackHole (honestly, I use mattress topper from Wal Mart). There is also a wad of stuffing resting in the bottom 1/4 portion of the cabinet.
