I am starting to acquire parts to build my own set of statements II and have some questions about the crossover parts that I am hoping somebody can help me out on.
Being somewhat new to speaker building, the more I learn, the more questions I have about it. In the past I have built the Aviatrix MT kit and then the tabletop Isetta from plans, both of which I am really enjoying.
So, as far as capacitor selection is concerned, I plan on using Clarity CSA for the tweeter and mid (smaller values) and Clarity PX for the 100uf cap. For the woofer, does it matter all that much about brand? Specifically I am looking at the ASC 60uf lti 4-5 cap (mainly for price reasons, can't find any info on these what so ever).
I ask this for two reasons:
1) After reading a bit it seems that the different caps affect the higher range more than low (maybe I am wrong here?)
2) Because the cap goes to ground and isn't in the direct signal path of the driver, does it have that much impact on the driver (as long as it is still a poly cap)?
Is it bad to mix capacitor brands within one speaker build?
With the steel inductors, it calls for 15 ga wire, would it be a problem to go with 14 or 16 in the same 7.0mh?
I am sure I will have more questions as time goes on, thanks for any help you can send my way.
