I'm going to use the Dayton Esoteric ES180TiA as the woofer in a 3 way. Modeling the bass I see this is a woofer that likes small boxes and/or low tunes for flattest response compared to other typical drivers, otherwise there is a considerable hump at tuning. A 17 Lt. box @ 35hz produces a fairly flat response (blue in the box model pics). But as this will be crossed at 500hz I knew there would be a considerable inductance hump around 100hz - pretty typical. It occurred to me that I could use a bigger box (22 Lt.) @ 40hz (red in the box model pics) to offset somewhat the effects of the inductance hump. To test out the probable inductance hump I made modeled a 4th order crossover for a driver I have measurements for and is similar in impedance: SBA SB15 poly cone. Here is a pic of that with raw driver response in box, crossover applied, and crossover transfer function.
So comparing that against the box model looks like it does complement the inductance hump nicely. However, group delay is worse, and I need advice on whether the result is concerning?
