I have a less than 2 year old LG 4K tv that has decided to stop accepting HDMI input. I get no signal error. The internal Netflix etc. works fine. Searching the net I found a site that claims if you remove the HDMI board and bake it at 385* for 10 minutes it will fix the bad solder joints and good to go. http://zedic.com/lg-42dl550-fix-repair/
Does this make any sense or sound reasonable? I can sort of see how it'd work.
I'm told a repair shop is $100 to look at and final repair likely 400 for a new board. It was a $900 tv when I got it. I'm thinking $400 is too much for this set. So trying the baking is intriguing. But since Netflix and Amazon work for now I'd hate to do something that'd kill it completely.
Thoughts? Is this a hoax like drilling a hole in you're iPhone or legit option.
