This questionnaire is for a school research paper, and I would appreciate as many responses as I can get. I understand that building loudspeakers involves a lot to take into consideration when designing one. But, for the sake of this paper please answer the following questions Yes or No, knowing that I understand there is no one size fits all approach. Designing, building, or buying our own loudspeakers adds a certain element to what we perceive or hear in a loudspeaker, making the audiophile topic highly subjective. I would like to get an idea of the averages concerning the questions involved.
Questionnaire:
Considering a room size of ~400sq. ft., with typical obstructions. A subwoofer is used, and crossed at 80Hz. The build is for front LR mains and consists of drivers no larger than 6.5 in. Cost and build complexity is not considered. And, multiple listening positions is the goal.
1. Is the phase audible at frequencies other than 180 degrees out of phase?
YES, or NO?
2. Considering phase shift is non-linear throughout the room at different frequencies, does it matter if it’s introduced by the speaker, if it can’t be controlled anyway?
YES, or NO?
3. Is the time alignment problem that can be introduced when using a 3-way 4th order crossover, important in considering whether or not to use a single driver or simpler (less components) two-way design?
YES, or NO?
4. Is a time aligned crossover important considering that the other components in a stereo introduce their own misalignment, i.e. Microphones/distance in recording, filters and enhancements added to the recording before release, amplifier used and any equalizers, DAC and ADC, and speaker voice coils not aligned?
YES, or NO?
5. Does the number of components and complexity of a 3-way 4th order crossover add more distortion and phase/time shift than any intermodulation introduced by using only two drivers covering the frequency range of 80Hz-20KHz? Room size considered.
YES, or NO?
6. Do you believe intermodulation distortion is audible in a two-way speaker given the parameters listed above?
YES, or NO?
7. Considering the cost, complexity, and time involved, would you build a two-way or three-way loudspeaker for the conditions stated above?
TWO-WAY, or THREE-WAY?
Questionnaire:
YES, or NO?
YES, or NO?
YES, or NO?
YES, or NO?
YES, or NO?
YES, or NO?
