I'm new to this and have done a few simple woofer/tweeter builds and I'm ready to step it up with some serious towers. I'm sure the info i seek is out there i just can't find it.
My next build will be a TMMWW or maybe 3 woofers. Not sure yet. The question is do you isolate the subs from the rest of the box and if yes do you have separate enclosures for each sub? I would think the subs would interfere with the other speakers.
i see a lot of builds where it all one big enclosure with baffles and bracing. So do you just add up the volume required of each speaker and make the whole tower that size?
Hope all this makes sense.
