I am looking to start a new build using the RS drivers that I already have on hands,
Designs I've looked at -
Tony's Black Box - http://www.htguide.com/forum/showthr...-The-Black-Box
diVine Audio - Canaiolo - http://www.divine-audio.com/canaiolo/
Jim's finalists - http://speakerdesignworks.com/Finalists_1.html
The Khanspire - http://www.divine-audio.com/khanspire/
And also the long RS52 thread - http://www.htguide.com/forum/showthr...-with-the-RS52
The RS52 as various threads show is a very good midrange, as long as you take a care of it's freq peak in the higher range with a notch filter or cross low to a tweeter.
The RS28 as well, capable tweeter that can be crossed low, I am thinking 2.5k-3k range to the RS52.
The RS225 I am thinking shouldn't break up early like the RS270, and with a pair of these sealed it should be capable of producing clean bass, even when played loud?
Also, since the RS52 is sealed, this will make the TM section simpler to do as well, a bonus
Having said that, does anybody see any issues with the above combo, or better yet have anybody tried it and want to share results? Even if simulated, to get me started in the right direction on this project.
Thanks!
Thanks!
