It is really crazy, once you rolled in this diy audio world you can’t get enough of it . Even if you keep on reading and every time you read things you not knew of. Maybe that’s why I can’t get enough of it
So like I said I read some nice things for like a week or so and of course when you are reading you get ideas for new speaker but I still have some questions or things I like to, to hear a second opinion off.
I would like to build a 2-way (MT) design with a Fountek FW146 (I know ZA14W08 is probably a better choise but not avaible in Europe as far as I know). Because of the non-linear distortion of the Fountek rising at 2k it needs to be crossed let’s say a bit over 2kHz 4 th order (read it from other pro’s but I think the same about it since I know what that’s all about, non-linear distortion, really interesting )
Non-lin. measurement at the bottom of this web page
So the most important parameter for my tweeter was a low fs and if it was possible a flat freq.responce and cheap if possible .
I found 2 Vifa tweeters
*BC25SG15-04
*DX25TG59-04
The first one has a more flat freq. response but the fs will be maybe at his limits, that is what I don’t know for chore. (strange also is that the measurements from Zaph audio are a bit differend??, there the freq. response lowers 2-3db from 8kHz)
The second one has a lower fs but a peak in the freq. response at let’s say 15kHz and is a bit more expensive . But maybe I can take here a lower order in the X-Over.
So which would be the best tweeter to choose, or is there one I overlooked with a low fs and a nice freq (and not to expensive). response to work with??
Thanks in advance!!
Brecht V.D.
*BC25SG15-04
*DX25TG59-04
Thanks in advance!!
Brecht V.D.
