hello ht-guys
i'm pit from germany and start this thread for building a clone of raal's smaller omnis the ones dlneubec had a try on.
first let me say a few words to my person. my main profession is guitar teaching ( i've been studying classical guitar at the conservatory nürnberg ). added to that i'm also building guitars classicals western and also electro guitars. since long i'm a diyer from repairing my car to building a cnc-router.
to speaker building i'm quite new. what i've already built is an open baffle speaker using two 12"speaker fullrange and on top a beyma bullet tweeter cp22 separated by a condenser only just built on an afternoon and screwed together. but that's also the way it sounds like that means for to make it sound good i have to work on some crossover. what i like from the current state is the dry and punchy bass without boomyness. but this alone doesn't make it a good speaker ;-)
not too long ago my brother was asking me whether i want to build a speaker system for him. cos i'm reading on speaker building forums since long ( and this ht-guide is one that i really do appreciate ) i could make a few suggestions and the raal omnis is the one he has choosen.
what can be found on the net about this speakers i've mostly read. especially dlneubec's thread about his contrappesos i've already been reading a few times. i've to say this is very well documented by dan !! thanks for sharing your experience. it's also very appreciable that aleksandar the designer of this speaker is chiming in and telling the ideas he had when he designed the speaker and what one has to care about to not change his design. again i have to say thank you aleksandar for sharing your knowledge with the diy-community !!
in the following i'll describe the actual state of affairs :
i've already bought the wideband speakers that will be used for the midband and if you follow the link you can have a look at it :
looks like these are quite well build and i'll cut the surrounding of them down to 80 mm diameter 'cos the stainless steel tubes they will be fit into have the same diameter. i'll work the same way dan did and cut those tubes into three pieces so it's easier to fit the tweeter. into the middle tube a slot will be laser cut and maybe also the holes for holding the tweeter.
for the tweeter i want to use a ribbon tweeter but the fostex tweeter raal suggested is hard to find at least here in europe and if you're able to find it it's very expensive ( think it's sold for around 130 euro a piece ).
i've found a few others that probably could be used instead of the fostex but i don't know exactly what specs they have to fulfill. it's clear they may not be too large that one can fit them inside the tubes. but the other specs ? maybe somebody can tell me something about that ?
these i've found :
( they are affordable at 109euro a pair. can be used upward from at least 4khz or higher and spl is 90 db )
another good candidate :
( nearly the same price but higher spl round 95 db. the horn i'd screw off and the cube at the backside i think contains the transformer and can also be screwed off then it's possible to fit them inside the tubes )
does somebody know whether magnetostats can also be used in this application ? maybe something like this :
( from their size they could be easily fit into the tubes. spl is quite high 98db and price is also 50 euro )
no matter what will be used and fit inside the tube the ribbon will be distanced at least 15 to 20 mm from the slot of the tube. i know that raal mentioned that it'd be an advantage to keep the slot quite narrow ( also the slot of the spacing of the two tubes ). it would be quite easy to rout a plastic piece on my cnc that connects the tweeter to the tube slot but i dont know how this "channel" should be sized or which curvature it should follow ? maybe somebody has an idea how this should be done ?
dan also used some foam pads on top and at the bottom between the tubes to form kind of a waveguide or horn. would be quite easy to cnc-rout something like that but i don't know which curvature it should follow to work best as a horn or waveguide. in the end it will look similar to a jbl 2344a-biradial-horn.
i want to build the woofer the same way dan/aleksandar did. let's say a tube with a diameter of 300 mm and a woofer on both ends. when i toy around with winisd with a closed box ( with 60 to 80 liters ) i will get down not deeper than 50 to 60 hz. i think with a vented box i could reach deeper but a closed box design has the advantage to sound less boomy if i'm right ? probably i'm not useing winisd correct i don't know. how deep could i reach in the best case ?
crossover will be active with the behringer ultra drive pro dcx2496 so i can toy around with different x-over frequencies and different filters.
okay i will have to use six poweramps to drive the speakers but if i'd use a gainclone design it won't be so expensive. probably something like this :
as far as i'm informed 'til now it's not unproblematic to manage the volume control with the behringer device. it would be best to put the control between behringer output and the gainclone but with volume potis it won't be practical. does anybody know a possibility how to manage this otherwise. probably i can do it electronically with a sort of volume ic ?
this is how far my design ideas have grown. don't know whether my decisions are correct and hope there are knowledgeable guys in this community who can and also want to give me a little help on this project or tell me if i'm right or where i'm wrong.
thanks in advance for giving me some support.
best regards
pit
these i've found :
best regards
pit
