I realize this is the place for speaker DIY....
But...there are other areas of DIY dealing with source & power.
Dan (aka PewterTA) & I have recently been experimenting with Mu-Metal & musical grade cork.
Here are the mods to my Schiit Gungnir DAC using the cork & Mu metal
CAUTION - Graphic Audio Porn Depicted
GUNGNIR STRIPPED TO ITS ESSENTIALS
IT HELPS TO HAVE THE RIGHT TOOLS FOR THE JOB
CUTTING THE CORK PADS
CORK PAD FITTED TO ONE OF MODULE BOARDS
CORK PAD ON ONE OF THE MODULE STAND-OFFS
CORK PADS FOR MOUNTING THE MAIN BOARD TO THE CHASSIS
SORRY FOR SOME BAD CLOSE-UPS….NOT MY Camera’s FORTE’
The Transformers are Soldered Directly to The Chassis So I Could Not Isolate Them with Cork.
They are Next To The A/C Mains, and Solder Terminations on the Board are Dangerously Close to Where I Want to Put the Mu Metal.
I Put Some Silicone Over the Solder Joints to Insulate from Possible Contact with Mu Metal.
You Can See My Hifi-Tuning Fuse, Too
Mu METAL IS CUT……
…IN POSITION & TACKED DOWN WITH SOME SILICONE
I can only say one thing.......
This is some Amazing Schiit!
The results are quite more than obvious.
Significant increase in soundstage width, height & depth.
Any recording signatures such as room acoustics or other ambient info is so palatable it makes the OEM seem like eggs without salt.
Much better with subtle details (which was pretty effen good to start with).
The overall realistic dimensional presence has me grinning till it hurts.
It is one of those upgrades that makes you want pull out all your favorites to hear all the new information that you going to hear.
The cork alone helped......(yes, I tried with just the cork, then added the Mu metal)
Isolating the X-fromers sent things over the top.
Mu METAL IS CUT……
