Would adding a second woofer be problematic? I have 4 and would like to build a full range, music only speaker. I'm sure that the consensus would be that the bass is adequate as is but for sake of argument...would it work? would I need to tweak the xover a lot? Another 35 liters of cabinet would be needed I'm guessing which is perfect for me. Thanks for any input.
Extra 225 for Finalists?
Jim Holtz should really respond to this, but what you're heading in the direction of is a Statement II, using the same midrange, I believe. Different crossover, of course. trying to convert the Finalists into a 3.5 way may be possible, depending on driver sensitivity, and padding changes, but it's not trivial. Professional road course, do not attempt this at home, etc. :Wthe AudioWorx
Just ask Mr. Ohm....- Bottom
Connecting the 225's in series and alter the crossoverparts accordingly should work in theory... :P ...but maybe not in reality...
Would require something like this http://www.parts-express.com/erse-su...-coil--266-952- Bottom
Or just build the original Finalists and use the extra 225's for these: http://www.audioheuristics.org/markk...-duet-file.pdf
The make a shoot-out with a lot of pics! :rofl:- Bottom
In theory, doubling the inductor and halving the cap should work. The spl stays the same. Passive crossoverdesign is not my thing but it is my understanding it will work. Hopefully someone more knowledgeable will confirm.- Bottom
One thing to keep in mind is that this will create a bass section with a nominal 16 ohm impedance. There is absolutely nothing wrong with this, but you will need an amplifier of considerable voltage swing in order to realise the additional SPL benefits of having two RS225s, rather than the single. Of course, if all you're after is the lower distortion that two drivers will net you, rather than more SPL output, then this doesn't really matter.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
Now with website. www.5een.co.uk Still under construction.- Bottom
Interesting approach. You've just gotta be able to swing some voltage to drive the higher impedance woofer setup. Of course, that's what increased power handling is all about.
Now, what if we built a Wavecor Ardent with 4 woofers per side? But it would require a 10 mH series inductor, too! i think then the mid and tweeter setup might become the limiting factor, though... it's fun to speculate.
I can see this idea for the Finalists possibly working pretty well- dual RS225's would definitely give it a leg up in output level and lower distortion.the AudioWorx
Would 2 4 ohm drivers in series solve any of the higher voltage needs? or just create more problems? I'm probably going to cut two baffles and try with one 225 then with 2. Then I'll have to sit for hours and hours listening to music to figure out which one works for me. I'm practically a martyr!
Thanks for the input! My son has been dropping not so subtle hints about how my NatP's would help with his music recording so we'll see if they are finally de-throned. Gonna miss 'em if so. Come a long way since the DIII's!Hola from El Paso!- Bottom
It would only create more problems. The reason why the two 8 ohms in series will work is because everything remains exactly the same. The voltage sensitivity remaining unchanged is key to this.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
