are these tweeters with ferrofluid ?
Ferrofluid ?
Tags: None
I do not think so.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
Now with website. www.5een.co.uk Still under construction.- Bottom
I was actually going by the impedance maxima and sharpness. Usually when ferrofluid is added it dampens the impedance peak quite significantly. Sometimes it can be a bit confusing though. Scan speak appear to be quite vigilant in mentioning which tweeter do and which tweeters do not actually have ferrofluid in the gap. I am sure if you emailed them that they would reply and let you know. The impedance of the tymphany DX25 looks very similar to the Scan made one, so it is a little confusing.What you screamin' for, every five minutes there's a bomb or something. I'm leavin' Bzzzzzzz!
this is the answer from scan speak :
- D2604-830000 is with ferrofuild
- D2604-833000 is without ferrofluid
i'm waiting the answer from peerless- Bottom
