I have a question concerning inductors and cross-over wiring. I'm quite familiar with inductor to inductor placement guidelines, but am now wondering about their affect
on any wires running within the magnetic field produced.
Example: An air-core inductor is oriented horizontally on the crossover board, so that the magnetic field runs primarily vertically. Wiring connections are run under the crossover board and some wires happen to run within the magnetic field of the inductors.
Is the effect of any induced voltages so small not to be concerned with or should the crossover board be re-wired to avoid this entirely? I would have just re-routed wires to begin with if I had questioned this before four crossovers were soldered, hot glued, and mounted.... ops:
Thanks for any guidance - hindsight seems so much more intelligent :roll:
