I have a buddy who'd like to build a subwoofer and I've been out of the loop for quite a while in terms of what the good drivers out there are. Can I get some suggestions for a good driver to use? The possible project would probably be a simple box, sealed or ported, and could range anywhere from small and reasonable to total overkill.
Subwoofer recommendations
The Dayton Ultimax seems to be the latest rage over at PE.
12" version of that works pretty well, too- personal experience. But if he's got room a 15, there's nothing that beats swept area. I tend to recommend sealed for transient definition and low overhang.the AudioWorx
Just ask Mr. Ohm....- Bottom
