Everyone seems to hot glue crossover components to the board. Dumb question. Why isn't the same adhesive used to glue to cabs together (PL, liquid nails, etc) used to secure crossover components to the board? Sorry if this is a speaker builder 101 question... :roll:
Adhesive for crossover components
Hot glue is not a structural adhesive and, in the case of xover components, can be reheated to allow quick and easy removal.- Bottom
SEOS 12/AE TD10M Front Stage in Progress- Bottom
Acrylic latex caulk works just as well. I probably like it a little better because it doesn't create those long spider web like strings when you pull the glue gun away. It seems to stick to the hardboard I use for crossovers and it peels off parts if you need to make changes. But you still need zip ties for the heavy parts. Personal preference.
-BobLast edited by BOBinGA; 09 September 2013, 10:29 Monday.- Bottom
+1 for zip ties to attach crossover components to a board. I have used short zinc wood screws to attach the boards to the inside of the cabinet when I wasn't sure about the crossover. For my recent build, though, I just hot glued the board to the cabinet. Either way works."MMMMMMM..... Floor Pie..... Marge, where's the silver digging thing?"
-Homer- Bottom
