Currently using the Khanspire design for my main speakers. It's actually been five years since I built them and they've been great. Now I'm looking to downsize as we're planning on moving to a few different cities and moving the Khanspire's around is not the most convenient thing ever. So with that in mind I'm thinking of new mains and matching center channel and a new subwoofer to go along with them (my current sub is pretty . Even a large bookshelf speaker with stand would be much better. There's a million designs out there so hard to figure out where to begin...A design that could utilize some of the Khan's components would be nice. I consider the Khan's to be pretty high-end would like something in their class...Or better. :-) For all speakers I'm looking for excellent music performance and they will also be used in home theater.
Help with downsizing from Khanspire
Here's one little bit smaller and uses almost all of your drivers. http://www.htguide.com/forum/showthr...amp-TMWW-Mains There's a center design to go with. For bookshelf size consider http://www.audioheuristics.org/proje...ence_rs225.htm- Bottom
Nat-Ps are nice. I built a pair for a friend in tower form. While I haven't done a direct comparison, I tend to like 3 ways and the 3 way tower would end up almost a foot shorter than a Nat-P tower since there isn't a woofer above the tweeter.
Max SPL on the 22528 might be limited by crossing so low but empirically I like the bass capability of the 225.
Life's full of compromises. In my SAF world a 5" MT is a big speaker.- Bottom
How much smaller? I've done a few designs that might work (as have others, but I'll only speak to mine.)
In a 3-way, the In-Khan might do the trick (there's a version intended for regular placement, not just an in-wall version) in a bookshelf sized box. A bit bigger, but still smaller, might be the Garnacha.
CdiVine Sound - my DIY speaker designs at diVine Audio- Bottom
cjd,
Any of those designs you mentioned would be fine. Even the Garnacha looks quite a bit smaller. I've been debating on doing a 2-way (or 2.5 way) or possibly a 3-way design that doesn't use the RS150. Not that there's anything wrong with the 150 but I feel that if I were to nitpick I think it may be the weaker point of the Khan's to my ears at least. Then again maybe it's my equipment and room that makes me perceive that.
To Bob or anyone else who'd like to comment, what qualities do you notice in a 3-way that tends to sway you that direction over a 2 or 2.5 way design? I haven't really ever sat down and compared them directly but I know I've enjoyed all three types.- Bottom
To me, three ways tend to sound more realistic and almost effortless when pushed. I think it's because it allows driver selection to minimize abrupt changes in power response and choosing a mid that will go high enough that the tweeter is not stressed at any level. The RS-150 isn't terribly smooth up near 2K with the beginnings of cone breakup, which may be what you are hearing with it as a mid.
You do need enough listening distance to allow integration, so maybe consider a 2 way with bass bin if you're possibly heading for small spaces. Adds a bit of flexibility.
If you're looking for a mid change, consider a design with a Seas Excel W15CY-001 or Zaph ZA14. I love the W15CY in a small room 2 way or as a mid. The ZA14 looks to be Zaph's clone of it with a bit better cone breakup control. Haven't heard it though.- Bottom
This thread breaks my heart. I refuse to participate.
(that and I think CJD has this one covered.)- Bottom
FWIW, the Khanspire and the Garnacha treat the midrange rather differently. But, it's a very picky driver to use as a mid.diVine Sound - my DIY speaker designs at diVine Audio- Bottom
Ryan,
I know, I know. The Khan's were my first build other than a sloppy build I did of a car sub 15-16 years ago and they've been great...Wait does that mean I'm officially starting to get old now? I think their size may just end up being a little too much once we move (especially considering they're physically bigger than the gf, not that she really cares either way though).- Bottom
The Garnacha also has notably better phase integration across the board - something it shares with the In-Khan-neato (and the first design I'd done that really pulled together that way for me) - there's something that extra bit special about the way it presents things. I hadn't noted hearing a design that did that till we fired up the In-Khans for the first time. One of my favorites so far. I keep coming back to the monster 3-ways, but they've never been perfect for me in the midrange and miss a little of the magic; on the other hand, they're something special to listen to still, too. Plus, I don't have the Garnacha here - I gave them to my sister.
There are obviously many options out there (though fewer that use at least some of the drivers you have on hand) and many more not yet designed. It depends on the journey you want to take.
