Linkwitz Pre Amp modification
  • oneoldude
    • 203
    AN AS-BUILT SCHEMATIC A BIT DIFFERENT FROM THIS ONE CAN BE FOUND AT POST #12 BELOW. SUGGESTIONS ARE STILL WELCOME.
    This is a major edit of the original post. I will bump it below to hopefully get it going.
    After thinking about it I decided to go to the mountain and use the Linkwitz circuit for my measurement mic preamp, but with a couple changes. Will you all please check me out?
    The Linkwitz circuit is designed for capsules that are cut for greater headroom. The capsules are then referenced from ground to V-.
    Trouble is that the WM61A capsule is obsolete and I understand that the ones available for purchase are often not genuine. But there are WM6X series capsules that cannot be modified and they are available and cheap. So I thought why not design the circuit so that it can handle uncut as well as cut capsules. My capsules are all uncut but I may try out cut ones in the future.
    So, I figured a switch could be used to switch the capsule reference from "ground to V-" to "ground to V+". That change is on the schema below.
    By putting all the front end stuff in an XLR connector, a simple switch of mics on the end of the cable and a flip of the preamp switch can accommodate a variety of capsules and modes of operation.
    The Linkwitz circuit has a gain of about 10 dB. The circuit I show is a clone of the Linkwitz version. But R3 could be replaced with switched resistors and provide a gain variation of 10, 20, 30 and 40 dB. At higher gains the effective R3 starts to get pretty small. Am I in trouble there? Would it be smarter to only have two levels of gain, like 10 dB and 20 dB? Or is a fixed 10 dB just fine?
    I also decided to throw in a "floating capsule" front end too. The idea comes from the Naint Studio site (look under "Schematics" for "basic" and under "The 'Linkwitz' mod") here: http://naiant.com/about/microphonedesign.html
    The output of the preamp will go to line-in of a sound card (M-Audio Transit in my case).
    The resistances in the circuit were chosen by Linkwitz to keep noise down. Is there any good reason to change them? I understand uncut capsules like an input impedance of about 20k or higher.
    And last, how long a cable can can these front ends push signal down to the preamp before the high frequencies begin to be cut? I have seen home theatre mics with cable lengths of 20 feet or more. How far can I go with mic cable? Linkwitz suggests less than 30 ft with a cut capsule. What about a stock capsule or a floater? I could figure it out if I knew the output impedance of the capsules in each mode of operation. But I don't.
    What have I missed?
    Of course a simple one BJT or one FET buffer for each of the front ends would allow longer cables. But I do not know how to design them. So any ideas are welcome. Probably BJT versions are better cause no fiddling is necessary to make them work (and I have 2N5210/2N5087s on hand). Ideas?
    BTW, I call this the Heresy Project because it is unbalanced from alpha to omega and it incorporates a floating capsule as one of the front ends. Both of these options are considered heresy and an abomination by certain folks at certain forums that cater to the Pro Audio crowd.
    Thank you all for whatever help you are able to give.
    Here is the circuit:
    oneoldude :later:
    "The race is not always to the swift, nor the battle to the strong, but that's the way to bet" - Damon Runyon
    "De Gustibus Non Disputandum Est" (There is no disputing taste) - Ancient Roman Saying
    • 15297
    Been extremely busy- will look at this soon, but might be as late as next weekend when I'm in Austria on business. GF going into hip replacement surgery Wednesday, and I'm leaving Thursday.
    • oneoldude
      • 203
      Good luck with the operation!
      oneoldude :later:
        Ditto. Pending hip replacement makes your hiking adventure even more impressive.
        • oneoldude
          • 203
          This is a bump because the first post in this thread has changed significantly.
          oneoldude :later:
            • 15297
            Thanks- will review! We're really scrambling right now between her operation (short notice, 4 month early due to a cancellation by someone else) and my very short notice travel- just got the last of the hotel reservations back today!
              • 15297
              We're both kind of agreed that the next vacation won't be 120 miles of hiking... :W believe me, that's a lot of distance on your own two feet for a couple of people that haven't seen 60 for a while! But their was a certain sense of accomplishment at the end...
              • oneoldude
                • 203
                Congratulation on your successful effort.
                How long did it take to do 120 miles?
                oneoldude :later:
                  Jon is more expert than I, but some thoughts while he is reviewing.
                  At 10K input impedance, a 1 uf film cap is plenty. For exmple, http://www.mouser.com/Search/Product...-MKT1817510064. Digikey has similar. You can also go with a 4.7 uf cap if you're really worried about that bottom end. http://www.mouser.com/ProductDetail/...7ixBYq5ZYks%3d
                  Same thought on your output caps. If the input of the next stage is reasonably high impedance, 1 uf should be enough. Of course you can parallel multiples.
                  Be sure C5 and C6 are as close to the power pins on the chip as possible with minimal leads to ground. I apologize if you knew this but many beginners aren't aware of the importance of bypass cap proximity to opamps. It gets more important as the opamp gets faster.
                  Speaking of which, I tend to prefer FET input opamps, just because the input current on BJT inputs makes it a little harder to keep DC offset in check. Not an issue with your capacitor coupled design, though. Is the 833 a place holder or do you intend to use it? It's obsolescent, but still usable. Linkwitz uses OPA2134 a lot, if I use opamps that's what I use. If you're buying for this application, get the single version, OPA134 and save the trouble of grounding the inputs on the unused half. I haven't tried any of the newer super fast chips because my active crossover boards use through hole caps for power supply bypass. That results in a relatively long path to ground which can be trouble (instability) for the fast guys. Not intending to start a chip war, but I think the OPA2134 sounds cleaner than an NE5532 in my crossovers. Cleaner, loses some fuzz.
                  • oneoldude
                    • 203
                    BobEllis,
                    Thanks for the input.
                    With the lack of response to this thread it makes me think that DIY is on its last legs or already dead. Shame.
                    In any event, I am using what I have on hand and I will not be listening to any of it. This is for speaker measurement only. The caps are electrically larger than the minimum necessary but they are physically very small and what I have. I could use smaller value film caps that are way, way physically larger. But I don't see the point. Is there one?
                    Linkwitz says that if the batteries are within an inch or two of the circuit, no bypass caps are necessary. That will be the case here but I used some anyway and some electrolytics too. The bypass caps are at most .7" from the pins. Also, the 833 is internally compensated to be stable at any closed loop gain. Here is a pic of my prototype. I could move the bypass caps closer to the chip, but is it really necessary?
                    Thanks for reminding me to kill off the second amp. I forgot to do that.
                    Thanks again.
                    oneoldude :later:
                      Of course, use parts bin parts. Glad to see someone else building experiments on perf board.
                      I forgot to ground the unused half once, and it went crazy and the noise got into the side I was using.
                      If you get funny behavior like oscillations, move them or add another set close to the chip.
                      • oneoldude
                        • 203
                        OK,
                        I guess its time to put this thread to bed.
                        FWIW, the pic below is a schematic of my as-built of the circuit in question. It is nothing more than the Linkwitz circuit with switchable capsule bias and trimmer set gain. It should be a decent DIY competitor to the LINEARX M-31 shown here:
                        Here it is:
                        oneoldude :later:
                          So are you happy with it?
                          • oneoldude
                            • 203
                            Not yet fully wrung out. I have a couple cut and uncut MICs to finish then I will run a battery of tests and attempt calibrating new MICs against a calibrated WM61A. When done I will have a much better feel for it.
                            Also, when done I may do a full wrap up including wand design, capsule choice, cut vs uncut capsules and preamp setup as well as an easy DIY wand holder. If it works out really well I may even do a PC board. It will be a while I guess.
                            oneoldude :later:
