I need some advice on veneering. (yes, I have read many of the existing threads). Lets say you have a large CC channel box in MDF that you plan to cover with unbacked veneer using the TB II iron-on technique......because that is exactly what I am planning.
When you start to apply the veneer sheets, is it preferable to start with the least visible side first, ie the bottom, and then trim the veneer to size? It would seem that doing this would allow each successive sheet of veneer to cover the edges of the less important sides. Moving from bottom to back to sides to front to top, would result in the top and front sheets "capping" the edges of the other sheets, and leave a more appealing boundary. Is this logic correct?
I was also planning to use contiguous sections of veneer to cover the left side, top side, and right side, so that I could have continuity of grain across the edge boundaries. To do this well I would need to pre-cut the sheets with very little overhang for trimming. Is this a good idea, or more trouble than it is worth for a non-expert?
