I'm not sure which build to advice, and this site has served as a great resource.
These are for a home office/guest room/HT. Yes it's one room.
The plan is for either design, is to create bass-bins with a single 10" sub in lieu of a stand, the sub will be what ever works in the space provided and the budget allotted. Either l26 Roys, or Dayton References.
Eventually there will be a 15" sub taking over everything below 40hz.
I'm not glued to either design, however I feel a smaller speaker is dictated by the needs of the room.
Attempting to adhere to the equilateral triangle of placement, it creates the following conditions.
The front baffle of the chosen design can be about 24" from the front wall, and at least 1.5 feet from the side walls if not further.
The speakers center lines can be positioned about 76" apart (assuming the speaker is not wider than 12"), and each speakers center-line along the front baffle will be approximately 76" from the listening position. The listening position is about 90" from the rear wall, and as such 66" from the plane that's created by the speakers front baffles that are positioned 24" from said wall.
Since the listening distance is relative close approximately 1.9m, I thought it would isolate me to recommending these sort of designs.
Or should I be looking at the Statement Monitors, Finalists, or even some other design?
Primary use will be music (70%), HT/TV(30%).
